Any options for an uneven cylinder top?
92 v-max4
it has 1 head per 2 cylinders.
I found I had a warped head and a machine shop took .006 off the head. Put back on, still leaks from another spot. Discovered the cylinder itself has a detent, or indentation on top outer edge. What can be done to fix this. Can some be milled off the cylinder to make it flat again? If so, I am guessing the other side thould have this done also?
Thanks
