12-19-2007, 05:49 PM
bad gas mileage, why?
hey guys, i have a 1996 yamaha vmax 600 that is terrible on gas. i only get about forty miles to a 10 gal tank. is this normal or is something wrong?
12-19-2007, 06:06 PM
have you checked for leaks?
12-19-2007, 06:09 PM
yes
12-19-2007, 06:21 PM
Banned
wow i thought my t-cat was bad
12-19-2007, 06:30 PM
How do the spark plugs look? If they are all sooty and black, you probably have a choke sticking, etc.
12-19-2007, 06:33 PM
Is your jetting right? The wrong mains can dump alot of fuel through a motor.
2004 Arctic Cat F7
1997 Arctic Cat ZR 580
1972 JD JDX 400
1978 JD Cyclone 340
12-19-2007, 06:34 PM
i will check them, if not what else could it be/
12-19-2007, 07:34 PM
I think SnowRida gets just a little better that that in his Vmax 600...but not much!!
12-19-2007, 11:57 PM
Things to check...
clutch alignment, ski alignment, track alignment, bad bogey wheel bearings, excessively worn hyfax, worn belt as well as all the things mentioned. My little indy 440 was getting 5 mpg just after I got it I did the carb, it was spotless, did the rest, got it up to 14. My biggest improvement was aligning the clutches, they were a lot farther off than they looked!
Rebuilding the fleet!
12-20-2007, 12:26 AM
what is she running like? does it seam like it pulls really hard but goes no where? does it seem like its flooding out constantly?
12-20-2007, 08:32 AM
I have had to replace choke plungers because the ruber gets hard and lets fuel still pass! And yes bearings will rob power and milage! Even things like wear bars can make a diference. How about the belt a worn belt will make the sled seem to take off in like second gear and not shift fully.
12-20-2007, 01:29 PM
Braaap!
Haha you're still getting better gas mileage than I was the last day of the last season! (When I bought it)
I could literally find my way home by following the nice 3" wide line of gas and oil.
A needle that wasn't sealing on one carb and kept filling the crankcase full of gas and oil, and then the other carb had a sticky float and the main jet was... missing... yup haha the main jet was not installed in the carb.
On top of that, my rear idler wheels were worn flat.
I think I got 20 miles to a tank? That's being extremely positive too.
Previous owner really messed the old girl up but she's fixed now! (minus suspension woes... need to buy a rear shock)
Anyways: Do a good rebuild of the carbs and check your jetting. (if the plugs are not a nice brown colour)
Check your belt, track tension, track alignment, quality of the hyfax/slides and idler wheels and what not.
Check your ski's for missing chunks/etc. May be creating a plow effect.
Drive belt, clutches, airbox for blocks... if you don't find a problem in one of those areas than i'm not sure.
1996 Formula STX 583
2000 Polaris Indy XC 600 Deluxe 45th Anniversary
I feel no shame I'm proud of where I came from, I was born and raised in the boondocks
one thing I know no matter where I go I keep my heart and soul in the boondocks
12-20-2007, 05:43 PM
jetting and leak. same symptoms last season asked here and they had the right info (AS USUAL)
