Old 12-18-2007, 02:10 PM   #1 (permalink)
tlazzaro
Question zrt 800 tripple 1108 ??? what???
my husband passed away a few years ago.. and we have this sled a 1998 zrt tripple mod. to 1108.. does that even make sense...?? can any one tell me about this sled? i had a repair shop put new pistons and rings in last year and now i cannot get it started..?? any ideas?? any help is greatly appreciated...
tlazzaro is offline   Reply With Quote
Old 12-18-2007, 02:27 PM   #2 (permalink)
SawBlade
We think the 1108 comes from using three 800 jugs off of a pair of zr 800 twins. thats what the idiot standing next to me is saying. anyway, got spark, getting fuel,??? Thats a fairly heavy sled for a lady. May want to consider downsizing to a ZL 500 or so and with reverse. electric start is also a nice feature. those yellow bombardiers (ski doo) with the rotax motor offers all the goodies. Dont get me wrong, my favorite sled is a zrt 800 but that is a lot of sled to handle when it comes to weight and speed. If your not too attached to the zrt you may want to trade it in at the repair shop for a more user friendly sled.
Enjoy Every Single Day
95' ZRT 800 mine
79' Jag 3000 F/C wife's
99' KX 250 mine
2002 Honda CR80 son's
SawBlade is offline   Reply With Quote
Old 12-18-2007, 02:28 PM   #3 (permalink)
Skligmund
Alaskan Member
Skligmund's Avatar
Might have to add a touch of gas in the spark plug holes to get it started the first time of the year.
1980 Polaris TX-L 340 - Stock
Skligmund is offline   Reply With Quote
Old 12-18-2007, 02:30 PM   #4 (permalink)
paintballdude05
1st Assistant Highjacker
paintballdude05's Avatar
Yeah that thing sounds like a monster! I think getting rid of it his her intention here.
Old 12-18-2007, 02:43 PM   #5 (permalink)
tlazzaro
thanks.. for the info.. i cannot even ride it.. it throws me off when running.. but i would like it to start befor i get screwed trading it in..
Old 12-18-2007, 02:45 PM   #6 (permalink)
tlazzaro
it is a crazy sled.. but i would like to sell it myself.. but i need to know what i am selling.. i cannot even pull it the compression is too tough.. i have to have some one else do it.. sparking but not firing.. some times you cannot even pull it????
Old 12-18-2007, 02:47 PM   #7 (permalink)
paintballdude05
Getting her started before trading would be a big plus in terms of value. Is it good gas thats in it? If not that would be the start. Like skligmund said try the gas in spark plug trick before you start it up, not to mutch thought you dont want a fire or enything like that.
Old 12-18-2007, 02:49 PM   #8 (permalink)
tlazzaro
ok...i am pretty handy i'd like to think.. ill try it. could it be a problem that i didnt run it after having new pistons and rings in it???
Old 12-18-2007, 02:57 PM   #9 (permalink)
paintballdude05
Yeah possibly but make shure you break it in corectly or els you might have a disaster on you're hands. The new pistons and rings need to be broken in correctly so they dont explode. You should run mix gas of 50:1, corect me if I'm wrong, just to make shure eavrything is lubed right. Has it run since the new rings and pistons?
Old 12-18-2007, 03:00 PM   #10 (permalink)
tlazzaro
she started and ran for a couple minutes.. then we shut her down and now nothing. break her in how??? she is not a trail sled... so i am confused?? i was told not to run her for a long period of time??? so what a couple minutes a crack?
Old 12-18-2007, 03:03 PM   #11 (permalink)
paintballdude05
Not shure since its not trail, but for trail you got to run mix, let her warm up alot and go for a ride. When you ride arround try to varie the speed at witch you are going, no hard acceleration just be gentle. I'm not a pro so I may not be 100% corect on this, somebody with more experiance here should chime in.
Old 12-18-2007, 03:06 PM   #12 (permalink)
SawBlade
Here is a starting trick. if you have a propane torch, open the valve and feed some propane into the air box while someone is pulling the starter cord. Propane will help start the toughest engines (high compression)and works likes magic. Propane also has lubricating properties and is better than ether (starting fluid). If you are worried about lubrication, add a teaspoon of two stoke oil directly into the spark plug openings. Dont feed too much propane after starts and if it fails to start after 5 pulls, turn off the propane valve and let the sled air out for 10 minutes. If you got spark, propane will often be the little boost needed to get the blood pumping on high compression engines.
All of you nea- sayers out there who think this is a bad idea. Try it sometime. works like magic. Use it only on 2 cycle engines. For RC cars this in the magic touch needed for cold weather starting.
95' ZRT 800 mine
99' KX 250 mine
Old 12-18-2007, 03:10 PM   #13 (permalink)
tlazzaro
thanks.. will give it a shot.... appreciate all your info.. will check back later for any other info..
t
Old 12-18-2007, 03:10 PM   #14 (permalink)
SawBlade
Where are you from....I want that sled!!!!!!!!!!! sounds awesome
95' ZRT 800 mine
99' KX 250 mine
Old 12-18-2007, 03:11 PM   #15 (permalink)
tlazzaro
south east wisconsin.....
Old 12-18-2007, 03:17 PM   #16 (permalink)
SawBlade
got any pictures?
95' ZRT 800 mine
99' KX 250 mine
Old 12-18-2007, 05:05 PM   #17 (permalink)
tlazzaro
i am trying to post a coule pictures.. there not the best.. i am not photographer that for sure!!! but i cannot get them to go..
Old 12-18-2007, 05:09 PM   #18 (permalink)
tlazzaro
ok picture is up... under the general photo area.. search words... 1108 artic cat zrt 800 hooper racing engine......
Old 12-18-2007, 05:12 PM   #19 (permalink)
tlazzaro
pictures... are up...
Old 12-18-2007, 06:15 PM   #20 (permalink)
Snowy
Dont use propane to start your sled.
Snowy is offline   Reply With Quote
