12-17-2007, 03:46 PM
XC Edge 340 2003
Hi, I'm looking to louded my exhaust on my 340 seeing how it is very quite but, the silencer is welded to the pipe so I can't remove it, so I'm thinking about putting a hole in the pipe or the silencer how do I go about doing this?
-thanks
12-17-2007, 03:48 PM
Braaap!
Don't.
You will blow up your engine if you drill holes in your pipe.
If you want to make your exhaust louder you will need to buy a MBRP system or the like. Then you will have to properly tune you're engine with the new exhaust.
1996 Formula STX 583
2000 Polaris Indy XC 600 Deluxe 45th Anniversary
I feel no shame I'm proud of where I came from, I was born and raised in the boondocks
one thing I know no matter where I go I keep my heart and soul in the boondocks
12-17-2007, 03:52 PM
Like I said, i can't.. it is welded bro, they don't make an silencer for a 340 xc edge lol, I'm thinking about drilling a hole in the Silencer how do I do it? I know a hole in the Silencer wont blow it up, think about it dude.
-thanks
12-17-2007, 04:15 PM
bump
12-17-2007, 04:59 PM
I thought sno-stuff made one for it?
Maybe not....
12-17-2007, 05:04 PM
can't anyone just tell me how to put a hole in the welded sil. they can't make a sil its welded guys come on
12-17-2007, 05:07 PM
Leave it stock.
12-18-2007, 01:26 AM
Above The Arctic Circle
Just take your whole pipe off. lol THEN it will be loud. Its a 340 dude. Your not gonna get anything racing/performance out of it. Thats like putting a magnaflow exhaust on a smart-car. If you really wanted a pipe you could buy an aaen one. But in the end you still just have a 340.
01 Polaris RMK 136"
- 01 600 VES Engine - Uni Air Filters
- Sno Stuff Rumble Pack - Powermadd Boost Bottle
- Custom Painted Hood - Powermadd Bar Riser
- EPI Pro Series Clutch Kit - Xtra-10 rear suspension
01 Yamaha VK III 540 ( The TANK)
Out Of Commission Till Next Year
12-18-2007, 01:37 AM
Braaap!
... You could cut the silencer out and put in a glasspack or universal silencer or something... And then rejet and retune you're sled, don't forget to adjust the power valves, reclutch it too probably because it's not going to have nearly as much power down low... Or as much power up top because you're replacing tuned, excellent flowing welded exhaust with some homemade pipe that has never been tested and who knows what kind of backpressure it will produce.
If you drill holes in it you're essentially destroying the vacuum and pressure the varying exhaust pulses create that help pull exhaust out of the motor thereby creating more power. You will basically be killing all power you're sled makes.
Seriously, you're better off leaving it stock.
If you want it to be louder take the spark plugs off and drop some bearings into the cylinders. It won't last long but it sure will be loud  . (Seriously, don't do this either)
12-18-2007, 08:32 AM
Don't touch it! Its made to be that way for a reason. They don't make performance exhausts for them for a reason too! BTW, no need to be ignorant with us, we are just trying to steer you in the right direction!  If you don't want to listen to our suggestions then why did you ask the question in the first place??
2001 MXZ 700 (mine)
1999 Indy 500 (wife's)
1974 TX 340
1996 GMC Seirra Z71 (my baby  )
2007 Outlander 500
2003 Foreman 450 ES (farm bikes)
12-18-2007, 06:31 PM
wanna bee sleder
Hey guys can ya help me out I am looking for a set of glass packs for my Yugo
1995 mach 1 670
1985 Pontiac fire bird 305 with a little extra
Drive it like ya stole it!
12-18-2007, 06:58 PM
Braaap!
Nah but I found you some high performance brake lines!
Cross Drilled Brake Lines - $69.95 : KaleCoAuto, Hard to find automotive items!
12-18-2007, 07:12 PM
wanna bee sleder
Originally Posted by RoadkillSTX
And all this time I just have been using trees go figure.
1995 mach 1 670
12-18-2007, 09:58 PM
I think he has probly drilled it by now. If we new where he's from we could potentially read about the fire in the paper....wasn't there some dude that wanted to drill pin holes all thru his exhaust because his "friends" told him it would flow better and boost performance? C'mon man you been doin' the jenkem? http://www.snowmobileforum.com/attac...072jenkem1.jpg
98 Jag (for the kids)
03 MXZ-X 800 (Blair Morgan)
12-19-2007, 01:10 AM
How come hes asking how to drill a hole?  Like there's a precision way to totaly ruin his sled.  Just get a drill a bit. Then drill until your hearts content. Might as well put lots of holes in it if you want to blow it up in style.
01 Polaris RMK 136"
12-19-2007, 01:19 AM
Braaap!
"HAHA after drilling holes in your exhaust make sure you take off the cover that's on the seat... It's just pointless weight, get it down to bare foam and ride like that! Easily make you're sled 6 to 7 times faster!"
12-19-2007, 04:36 AM
OK guys, enough with the flaming.
He's already made up his mind to drill holes in his exhaust and has absolutely no interest in listening to anything that does not give him his desired answer.
If he wants to destroy his engine, lets help him.
EVO.
Take a saw and cut the bottom of the silencer off. This will definitely make the sled way louder and also make a mess in the engine compartment.
It should run great for about 10 minutes before it eats the pistons.
12-19-2007, 11:31 AM
Jaded
OKay "Dude". If we have to tell you how to drill a hole in your exhaust system.....you maybe shouldn't be around anything mechanical, period!
Take the advice of some very smart people on here...leave it alone or have it removed properly. The weld can be cut. What do you think you're going to gain other than increasing your risk of burnin it up?????
Are you the guy that was giving the advice to one fellow on here to drill holes in his exhaust manifold.
