Old 12-16-2007, 03:26 PM   #1 (permalink)
reuterd
Arctic Cat Pantera Drop Case fill
I don't have a manual for my sled. Can someone please tell me where you add drop case oil (i'm low)? Also I don't have a ArcticCat dealer around and was wondering what else I could use for the drop case?
reuterd is offline   Reply With Quote
Old 12-16-2007, 03:43 PM   #2 (permalink)
dobbs
www.315er.net
dobbs's Avatar
what's a drop case?
dobbs is offline   Reply With Quote
Old 12-16-2007, 04:10 PM   #3 (permalink)
paintballdude05
1st Assistant Highjacker
paintballdude05's Avatar
Thats what cat calls the chaincase. There should be about 3 spots where you could put some in. There's the spot were you can check the fluid level/dipstick and there is 2 other spots where you could add, these are kinda like bolts that go into the chaincase. Just remouve and add proper ammount. Here is where you could go check out you're chaincase in the scematics to find out were to fill.
' + objMainFrame.arrApplicationTitle['EN'] + ' -- EMPARTweb*Version 5.2.2* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *
Old 12-16-2007, 04:57 PM   #4 (permalink)
reuterd
Thanks for the info, I will check out the sites
Thanks again
Old 12-17-2007, 10:29 PM   #5 (permalink)
kccats
I would drain inspect and replace it (12oz). To drain I drill a hole a hole at the lowest poit in the belly pan, then put an old oil jug with the side cut out. Then take the bolts out and it will drain. The fact that you're low on oil means there is a leak! It maybe a oring around the bearing or the case cover seal? Inspect the gears and chain too!
