Old 11-21-2007, 02:47 PM   #1 (permalink)
maiden9494
maiden9494's Avatar
black stuff leaking from my sled :s
hey just went out and moved my skidoo and there was a few black spots left on the ground from my doo . i looked through it and it was seeping through somewhere from underneath . i checked and it seemed to be coming from where the main pipe meets with a little thing that duels off into the engine ... i put my finger there and all black stuff was on my finger ? so whats going on . or is this normal ?
maiden9494 is offline   Reply With Quote
Old 11-21-2007, 03:03 PM   #2 (permalink)
Dennismc
Reverend Dennis
Dennismc's Avatar
Sounds like the Y Pipe gasket is bad, what you are seeing is the unburnt fuel/oil mix coming out of the carbs. (I think someelse will have a better explanation) but that gasket is bad, not to hard to replace at all...
Dennismc is offline   Reply With Quote
Old 11-21-2007, 04:32 PM   #3 (permalink)
IndianRvrShiver
IndianRvrShiver's Avatar
Yup!!...oil, gas, carbon soot & condensation....really makes a mess when the Y-pipe gasket leaks!! Just get some high-temp silicone (Permatex Ultra Black) & spread a thin coat around the gasket/grayfoil then re-assemble. Let it cure o'nite before you start it.
Old 11-22-2007, 09:11 AM   #4 (permalink)
kccats
This is a normal thing but, why is it ewusing oil etc? Is your oil pump set too rich? are you not getting a good burn? are you too rich on the jetting?
Old 11-22-2007, 09:40 AM   #5 (permalink)
This is residue of unburnt oil/gas/soot/moisture combination from not running the engine long enough for the pipe to get properly heated to operating temperature. This will happen every time until the engine is at operating temp.
Old 11-22-2007, 01:27 PM   #6 (permalink)
maiden9494
maiden9494's Avatar
ok so its normal ? dont need to do anything until we get some snow ?
Old 11-22-2007, 02:26 PM   #7 (permalink)
Dennismc
Reverend Dennis
Dennismc's Avatar
it is normal, but if it leaking from between the block and the y pipe, you need to replace the gaskets in there..
Old 11-22-2007, 05:40 PM   #8 (permalink)
maiden9494
maiden9494's Avatar
whats the block ?
Old 11-22-2007, 05:41 PM   #9 (permalink)
maiden9494
maiden9494's Avatar
by the way i got an sdi if that makes any difference
Old 11-22-2007, 05:45 PM   #10 (permalink)
Dennismc
Reverend Dennis
Dennismc's Avatar
The block is the main part of the engine. Where the y-pipe connects to.
Old 11-22-2007, 05:47 PM   #11 (permalink)
maiden9494
maiden9494's Avatar
ohh no . i think its coming from where the y pipe meets with the main pipe .
Old 11-22-2007, 05:52 PM   #12 (permalink)
BskidooC
BskidooC's Avatar
Well then you should pull the pipe and lube it up real nice with pipe gunk...
Old 11-22-2007, 05:52 PM   #13 (permalink)
Dennismc
Reverend Dennis
Dennismc's Avatar
Ok in that case, you want to check and make sure all the springs are there holding it together, and you may want to order a new inner gasket for that part.
If it is leaking there you have a air leak which will cause the backpressure to be off slightly...
Old 11-22-2007, 05:54 PM   #14 (permalink)
maiden9494
maiden9494's Avatar
ok how much will that cost around ? and will i be able to hold off from getting it at least another year ? because im selling it again next year , and thinking about getting a xp
Old 11-22-2007, 06:58 PM   #15 (permalink)
Dennismc
Reverend Dennis
Dennismc's Avatar
what year and make was your sled?
Old 11-22-2007, 07:00 PM   #16 (permalink)
maiden9494
maiden9494's Avatar
its an 04 mxz xps-II 600 sdi . in my pic.
Old 11-22-2007, 07:57 PM   #17 (permalink)
IndianRvrShiver
See post #3....read it again!! Now slowly this time.........
Old 11-22-2007, 08:37 PM   #18 (permalink)
Dennismc
Reverend Dennis
Dennismc's Avatar
IRS, sure, I get him all set and YOU step in to close the deal......
Old 11-23-2007, 06:24 AM   #19 (permalink)
maiden9494
maiden9494's Avatar
thanks for the replys but im still not sure what to do ... follow IRS ' advice or dmc.
Old 11-23-2007, 07:36 AM   #20 (permalink)
jagermiester
jagermiester's Avatar
Do what IRS said and I'm sure Dennis agree's
98 Jag (for the kids)
03 MXZ-X 800 (Blair Morgan)
