11-20-2007, 12:35 AM
I Keep Fouling My Plugs????
I have a 98 Polaris 680 ultra with PSI pipes and keep fouling plugs. I rode at Petersvile this sunday and I fouled 3 plugs...CAN ANYONE HELP!!!!
98 Polaris 680 Ultra with PSI pipes
1976 Chrysler SNO-RUNNER 134cc performance muff and cluch
1977 Chrysler SNO-RUNNER 145cc Big Bore and pipe
11-20-2007, 12:36 AM
Sounds like your too rich. Either lean it up a bit or crack her wide open more, get that carbon out of her.
11-20-2007, 12:54 AM
Ohh she's wide open most of the time, when you say too rich do you mean too much oil and not enough gas or reverse. I actually seems to happen while I'm ripping up a powder field or right after
11-20-2007, 12:55 AM
yeah too much unburnt oil is covering your plug and its not getting enough spark. Your rich. Start leaning down your main jets and play with your air screw a little bit
11-20-2007, 01:00 AM
OK I'll give it a try, do you think a hotter plug would be better also..I;m running BR9ES's right now
11-20-2007, 01:02 AM
Doing that would be a band aid fix. You should really just take the time and find out the best jets and just expirement until you get whats right for your machine, its better in the long run.
11-20-2007, 02:54 AM
LiFe Is OnE
I don't know if can help you but 2 years ago I had the same problem with my RMK 800 when I rode slow
the problem was a broken wire of the mix-pump cable that made unable the mix-pump to return in low position when I leave throttle
at low rpm I was always rich
WolfOne - RMK 800 151 SP 2001 - Europe, Italy!!
11-20-2007, 02:55 AM
Make sure that the chokes are not stuck partly open too.
11-20-2007, 06:53 AM
Go down no more thatn one size at a time on the main jets when you do change them.
11-21-2007, 05:35 AM
Alright thanks alot for all the info, I put the stock pipe back on and I'm going to try and find a place to test it tommorrow.
11-21-2007, 11:15 AM
There are two ways to foul a plug... you can be too rich on the jetting and foul a plug, or adding too much oil and foul a plug. If it's oil fouling, changing the jetting won't get rid of the fouling. If the plugs are wet/black when you are fouling, I would suspect oil fouling, and look at the oil pump. Make sure it's adjusted correctly and is not delivering too much oil. If the plugs are dry and black, then work on your jetting.
And like SEG said... only go one size in the jetting before you test, it doesn't take much to go from too rich to too lean, and too lean will burn hot enough to melt holes in your pistons...
Rebuilding the fleet!
11-22-2007, 03:43 PM
Thanks, it seems to be oil fouling but the pump is adjusted correctly, maybe I will make it premix, I also took off the PSI pipes and put the stock pipe back on, then downsized the jets 3 sizes total.
