I have begun to attempt to remove the head off the TNT. I am getting there, but the only thing keeping me back from getting the loose head off is the casing on the top of the engine. The exhaust manifold is in the way from being able to take the casing off. I dont see how to take off the exhaust, how is it bolted on? I cant really see a way to take it off because theres no room to fit any type of wrench in there if its bolted to the engine. I made a video to show you what i am talking about, hopefully it helps what i am trying to describe. thanks
Well I got the engine out...You were right tho, that shaft was part of the problem. But it required tilting the engine back to pop the manifold out. They just had force to keep them in...But the engines out, and ready for the rebuild. This engine is junk...Its had been leaking horribly in the bottom end. What type of parts would I need to find to do a complete overhaul? I also think I need to points ect, but i dont know where to start. Any help be appreciated..
