Old 02-08-2007, 05:52 AM   #1 (permalink)
WEATHERBY460
Ideas on overheating sled? v-max
92 v-max 4....If I ride for 20 min, then shut the sled off and leave sit for a half hour, then go ride again, after the engine gets warmed up the second time, my coolant light starts to flicker on and off. Stays on if I leave the sled sit and idle, but still flickers when driving it.
I replaced the thermostat and radiator cap. I removed the thermostat the other day when it happened and it was wide open, and slowly went back closed when it cooled off in my hand. So it is definetly getting hot in there.
I purged the air out of the back heat exchanges under the seat. I could hear air escape when I cracked them open.
What should I try next?
Thanks
Old 02-08-2007, 07:07 AM   #2 (permalink)
Are the exchangers getting warm? There still might be air in them. Make sure they are heating up. If they are not, they still need to be bled.
Old 02-08-2007, 07:58 AM   #3 (permalink)
kccats
Are there bubbles coming up at the cap? Could be getting compresion past an oring?
Old 02-08-2007, 08:34 AM   #4 (permalink)
G.T
G.T's Avatar
There are so many other variables which could/would affect the over heating. Are you losing any water? have you had any of the motor apart?
G.T is offline   Reply With Quote
Old 02-08-2007, 08:54 AM   #5 (permalink)
upersleder
upersleder's Avatar
are you sure its overheating and not a faulty light or sender?
2003 MXZ 700X
Old 02-08-2007, 09:47 AM   #6 (permalink)
tripletriple
tripletriple's Avatar
What type of conditions are you riding in? If it is hard pack, or ice, or if you are driving slowly all the time, that can also cause a sled to overheat. Just a thought.
2008 Ford F150 FX4 Plus SuperCrew 5.4L V8
2005 Ski-Doo MXZ Adrenaline 600 HO
2000 Bayliner Capri Bowrider 20' 220HP 5.0L Merc I/O
tripletriple is offline   Reply With Quote
Old 02-08-2007, 02:41 PM   #7 (permalink)
WEATHERBY460
How do I check for bubbles at the cap......I assume I remove the cap, let it run?????
Wasn't sure if I could do it that way?
Old 02-08-2007, 03:11 PM   #8 (permalink)
lrnnorth
Above The Arctic Circle
lrnnorth's Avatar
Sounds like you have an air-lock. Did you elevate the front of your sled while you bled the air out? Just a thought.
lrnnorth is offline   Reply With Quote
Old 02-08-2007, 05:56 PM   #9 (permalink)
WEATHERBY460
I noticed the tubes under my seat and the fins by the track are getting warm, not hot, but warm to the touch.
I also noticed my resivor tank is overflowing
My radiator is warm also, but not hot on the outside when I touch it with my bear hands.
Does this tell me anything?
Also....where can I find a temp gauge at...and where does the probe mount?
Thanks guys.
I still havent tried the head gaskets yet.....that looks kinda tricky. If I wanted to test head gaskets, do I just run the engine with the rad cap off and look for bubbles?
Also, I picked a jug of "stop leak" up today at farm and fleet....would it hurt to pour that in?
Old 02-08-2007, 07:14 PM   #10 (permalink)
G.T
G.T's Avatar
It sounds either like air or possibly the coolant system is pressurising, possible head gasket leak?
Old 02-08-2007, 08:51 PM   #11 (permalink)
Don't use the stop leak. Let's fix it the right way.
Old 02-08-2007, 10:39 PM   #12 (permalink)
kccats
If the head gasket is leaking you may not smell that sweet anti freeze smell, but with the engine warm and cap off and the front end up you could see air bubles continue to come up preety steady for as long as it is running and even for a few seconds after its off!
Replacing the head gaskets (orings) isn't hard, just drain the system as much as you can and remove the bolts in a criss cross patern and take it off. You'll need to remove the water passage too.
Old 02-09-2007, 05:59 AM   #13 (permalink)
WEATHERBY460
will order gaskets today...let you know next week...thanks
