Old 02-07-2007, 11:25 AM   #1 (permalink)
fbmbmx1211
Bad gas milage
I have it on my infamous jag. mabey a bad carb adjustment? the self mix is disconnected i run the 50:1 mix anytihng to do with it? let me know
fbmbmx1211 is offline   Reply With Quote
Old 02-07-2007, 11:36 AM   #2 (permalink)
tamacat
Try to catch my CAT
tamacat's Avatar
Why did you diconnect the oil injection???
ARCTIC CAT
Worthington Flip Top Trailer
Old 02-07-2007, 02:16 PM   #3 (permalink)
BC_Dan
First, check for leaks in the system.
Then, make sure the carb is cleaned with the appropriate jets for the altitude and temperature at which you are riding. Also check the plugs to ensure they are giving a good spark to ignite the fuel mix.
Then start looking at places that may be robbing you of power. Check all the bogey wheels for bearings that are frozen, check the track alignment, check ski alignment and condition of the runners, check the primary/secondary offset, make sure both clutches are clean and functioning normally, with springs that are operating correctly. Check the belt for width and for proper deflection. Lots of times bad fuel mileage is not a power issue; its an issue of the power delivered by the engine being robbed before it gets to the track.
Also, look for restrictions in the exhaust as well.
Pre-mixing at 50:1 should not contribute to poor fuel mileage.
Rebuilding the fleet!
Old 02-07-2007, 09:05 PM   #4 (permalink)
kccats
First what are you calling bad? 6-8mpg? What all have you done to it? How do you ride?
