Old 01-30-2007, 05:44 PM   #1 (permalink)
summit700
Ceramic coating
Im think about painting my pipe with this stuff and wornding if anyone has tryed it? Is it a good idea? Will it melt my hood now that i dont have that tin over it? And will i lose any hp now that the tin is not over the pipe to keep it warm witch i dont think that is what the tin is there for thoe?
summit700 is offline   Reply With Quote
Old 01-30-2007, 05:48 PM   #2 (permalink)
RedPolaris97
RedPolaris97's Avatar
If you're using a ceramic coating it should serve the same purpose as a heat shield. Actually, it should be better than a heat shield, because every sq. in. of the pipe will be covered. I would imagine you would get less heat under the hood and maybe a tiny bit more power. I'm not an expert on snowmobiles, but i'm taking this from prior general knowledge. Hope that helped!
RedPolaris97 is offline   Reply With Quote
Old 01-30-2007, 07:48 PM   #3 (permalink)
upersleder
upersleder's Avatar
are you talking the paint that contains ceramic or actual ceramic coating that you have to cure at 700+ degrees? i am building an oven to cure ceramic coatings now and have some to try, we are doing a set of headers for the race car first, then maybe my pipe for the sled.
if its true ceramic coating it should be just as goos if not better than the heat shield.
2003 MXZ 700X
Old 01-30-2007, 08:08 PM   #4 (permalink)
summit700
i dono its in a can lol there both the hight heat paint with ceramic in it and alot the ceramic coatin itself both in a can so i dono
Old 01-30-2007, 08:09 PM   #5 (permalink)
kccats
A guy on a different forum did his and they turned out great! I'm thinking of doing mine, but don't know where to get the paint. He said it was expensive like $15 a can! But he did a t cat triple set and the can with 2!
Old 01-30-2007, 08:10 PM   #6 (permalink)
summit700
holly that made to sence lol well they both come in a spray paint can 1 of them is high heat paint with ceramic in it and the outher is ceramic itself so im not to shur.
Old 01-30-2007, 08:31 PM   #7 (permalink)
Formula_Canuk
Back Out!
Formula_Canuk's Avatar
Neither will last long. Only way to do it is to ship it out and have it coated. The high heat paint does not react well too constant cool then rapid warming conditions. I've tried em on headers before.
96' Formula III 600 triple
02' XCSP 800 edge
Formula_Canuk is offline   Reply With Quote
Old 01-30-2007, 08:44 PM   #8 (permalink)
upersleder
upersleder's Avatar
that stuff aint worth a crap!
i have the real ceramic coating, it cost me $130/quart i am adding the service onto the powdercoating service i do. i also have high temp powdercoat. it will hold up on pipes and cans, better than any spray on stuff you can buy, if you want it done right you have to do it one of those two ways.
2003 MXZ 700X
Old 01-30-2007, 11:00 PM   #9 (permalink)
BC_Dan
I painted the twin pipes on my 700 rmk with the ceramic paint, it lasted about 4 rides before it was flaking off... sure looked nice when it was new, looks lousy after use. It does little to keep the heat away from the hood and little to hold the heat in the can. I went back to a stock single and dont' melt things anymore
Rebuilding the fleet!
Old 01-31-2007, 01:24 PM   #10 (permalink)
summit700
ok well thanks alot so maby its not such a good idea then but i hate listing to that tin on the pipe it has broke and rattles like crazy now i hate it.
Old 01-31-2007, 01:54 PM   #11 (permalink)
The tin is a heat shield to prevent melting of the plastic hoods.
