Old 12-19-2006, 05:59 AM   #1 (permalink)
WEATHERBY460
Is hyfax/sliders hard to install?
I see on my 89 wildcat I have to remove the suspension to install new hyfax....how complicated of a job is this to do?
Old 12-19-2006, 06:55 AM   #2 (permalink)
IndianRvrShiver
IndianRvrShiver's Avatar
On my FC's, you must loosen up the track quite a bit, first. Remove the screw at the front of the slide rail that holds the hyfax in position. Line up a track window at the rear & just slide it off the rail out through the window. You will prolly need some persuasion (hammer) to get it off. Spray the rail with WD-40 to help lube.
Old 12-19-2006, 08:43 AM   #3 (permalink)
redsummit
redsummit's Avatar
With my dad's rev we had to remove the entire rear suspension and then remove the hifax. If thats what you have to do i recommend having one or two people help you.
2002 Ski-Doo Summit 800 Sport RER 144"
CPI Racing twin pipes
COMING SOON
VFORCE reeds and longer track
redsummit is offline   Reply With Quote
Old 12-19-2006, 09:18 AM   #4 (permalink)
ac bigbore
ac bigbore's Avatar
getting skidfram out is the easy part
Loosen track adjustment bolts till track is quite loose. Remove rear bolts that go thru tunnel to skid. Remove front
bolts thru tunnel to skid. Put sled on its side by lifting
up by a ski spindle. Pull out skid. You may have to put sled on side before the last step, or alternate tipping on sides.
The trick is getting it back in. First attach the front skidframe bolts. Then the debate started on an earlier thread this fall on how to proceed. The back skid holes will not line up now without force. Some say to first unspring the skid and loosen the limiter straps before putting the skid back in. My method is to have 2 people handy if possible, and use a come-along attached to the ski spindle or something sturdy in the front of the sled, and one of the cross members of the skid near the rear attachment bolts. Have one person pull on the come along until the bolt lines up in the hole and slide it in. Repeat on the other side.
While skid is out, inspect all idler wheels. On an 89 you will likely find some bad bearings. Maybe replace the main springs- the sled doesn't have much travel to start with, and you want all the spring force you can get. Good luck.
ac bigbore is offline   Reply With Quote
Old 12-19-2006, 09:19 AM   #5 (permalink)
PolarisINDY500
SENIOR MEMBER
PolarisINDY500's Avatar
if you do what IRS said that is "easy". however, if you have to remove the track that is a bit more difficult. if you do remove the track id suggest using a ratchet strap to hold the rear arm in place. that way you dont have to fight to allign the bolt holes when you re-install it.
The Original Logo ->
Old 12-19-2006, 10:11 AM   #6 (permalink)
tamacat
Try to catch my CAT
tamacat's Avatar
Exactly!! I've done ALL my sleds this same way! I Never had to touch a skid frame to change Hi fax. Sounds like a lot of work for a part that slides on fairly easy. Just pull it off and push it on through the track clip hole(window).
ARCTIC CAT
Worthington Flip Top Trailer
Old 12-19-2006, 10:33 AM   #7 (permalink)
BRPforlife
A god among men
BRPforlife's Avatar
The track windows on the doo's aren't big enough . I don't know about his wildcat though. If you have any mechanical aptitude you should be able to figure it out with a few stubbed finger and scraped elbows.
Old 12-19-2006, 10:36 AM   #8 (permalink)
tamacat
Try to catch my CAT
tamacat's Avatar
I was not sure about the doos. Should be OK with that wildcat though.
ARCTIC CAT
Old 12-19-2006, 02:23 PM   #9 (permalink)
WEATHERBY460
think i will pass on this job for now...thanks guys...might tackle it after the snow is gone for the season.
Old 12-19-2006, 07:02 PM   #10 (permalink)
rgoers
rgoers's Avatar
If they need replacement - you better do it! If you let it go, you'll be in a lot deeper ($$$) in the long run.
Do what IRS said. It's EASY to do! I do mine in 15 or 20 minutes. Jack the rear up, remove the front screw, and tap the thing out through one of the windows in your track. Simple! Sometimes it helps to place a large screwdriver against the edge of the hyfax, and whack that. Don't worry about damaging the hyfax - you're going to throw it out anyway. Once you get it moving, it goes easier the more you have sticking out the back.
2000 440 Panther
1980 Jag 3000 F/C
