Old 12-16-2006, 11:52 PM   #1 (permalink)
DaN2525
02 polaris 440 pro x... stumped
pro x runs fine when first starting to ride, but if you stop it seems to flood when you hit the throttle... we have checked the needle and seat, the jetting, the carb settings, the choke... etc... we changed the coil, plug wire ends, and the plugs... all of this made no difference. weather we set it up to run lean or rich makes no difference to this problem.... the engine has just been rebuilt do to burnt rings... any ideas as to how to fix this problems would be great.....
Thanks for your suggestions.
DaN2525 is offline   Reply With Quote
Old 12-17-2006, 07:07 AM   #2 (permalink)
Make sure compression is where it needs to be. How did you "check" the needle and seat? Did you pressure test it? Also when was the clutch system cleaned last?
smallengineguy is online now   Reply With Quote
Old 12-17-2006, 10:38 AM   #3 (permalink)
upersleder
upersleder's Avatar
also not sure about the polaris's but when the stator starts going bad on the old doo's it will act like that. drop plugs and make you wonder whats wrong with the carbs....
2003 MXZ 700X
Old 12-19-2006, 12:22 PM   #4 (permalink)
DaN2525
sorry, compression is good and we RESEATED the needle. could a dirty clutch cause a problem like this? also if it were the stator the lights would dim significantly right... because they don't really change.
thanks again.
Old 12-19-2006, 01:11 PM   #5 (permalink)
The light and the ignition coil are two separate items in there.
Old 12-19-2006, 09:52 PM   #6 (permalink)
TUGHILLYAMMI
J. DRISCOLL
TUGHILLYAMMI's Avatar
Just for kicks, you wouldnt happen to have bar risers on that sled you are messing with do you or have tampered with the throttle cable?
TUGHILLYAMMI is offline   Reply With Quote
Old 12-20-2006, 08:58 PM   #7 (permalink)
DaN2525
the sled had bar risers from factory.. we had adjusted the throttle cables because they were set wrong by the previous owner.... the sled was doing this before we adjusted them tho. i took it for a ride today and if you pin the throttle it will rev up to about 4500 rpm and then bog down to about 3000 rpm and just sit there and smoke.
Old 12-20-2006, 09:44 PM   #8 (permalink)
newcatrunner
newcatrunner's Avatar
sounds like what my 99 cat 500 is doing...its at the dealers getting looked at...ill post when i get an answer as to the problem
snowmobiles are not a sport....they're an addiction
cheeky4:
newcatrunner is offline   Reply With Quote
Old 12-20-2006, 11:53 PM   #9 (permalink)
newcatrunner
have you checked for wires grounding out on framework anywhere?...just got mine back from repair shop and i had same problem..turned out to be bare wire grounding out
cheeky4:
Old 12-21-2006, 12:28 PM   #10 (permalink)
Proxj
Proxj's Avatar
Its a 440 there extremly high strong and they basicly suck. the motors are bad they ae extremly picky on jetting if you dont jet it right it melts pistons.
2002 pro x 600- slp can, handgaurds, 04 prox-r graphics, shorty seat, clear tank, race winshield, 136, 1.25 preditor track, clutched, geared, C&A razors
2003 outlander 400 ho
Proxj is offline   Reply With Quote
Old 12-21-2006, 06:03 PM   #11 (permalink)
TUGHILLYAMMI
J. DRISCOLL
bummer sorry i couldnt help. i'll try some research and see what i can come up with. i mean ive got plenty of time to look up sum stuff with NO SNOW here.
