how much does it cost to bore cylinders - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 20 (permalink) Old 11-27-2006, 11:50 PM Thread Starter
yamahog's Avatar
I need to get both done on my Deere. I'm not sure where to send them either. Anyone know?
Beep, Beep, Richie
yamahog is offline
post #2 of 20 (permalink) Old 11-28-2006, 06:13 AM
Any automotive machine shop can do it. Here it costs $60 each.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #3 of 20 (permalink) Old 11-28-2006, 07:26 AM
Not all automotive machine shops can bore that small. I know that we don't have any boring bars that small because the demand is too small to invest in the tooling. Check with your local motorcycle shop or even the aftermarker Harley shops. They'll be able to send you in the right direction to get your cylinders taken care of. Just make sure to verify the clearances before you install them. More times than not they will be wrong.....
mysunnshine is offline
post #4 of 20 (permalink) Old 11-28-2006, 08:39 AM
IndianRvrShiver's Avatar
Be sure you provide the new pistons when you have the boring job done, so they can set up proper clearance! Don't just give them a spec!!
IndianRvrShiver is offline
post #5 of 20 (permalink) Old 11-28-2006, 08:47 AM
I just fix 'em...
IRONDOG's Avatar
I charged $40 per cylinder- and guarantee a perfect job. Proper clearance, chamfered ports (relieved where needed), bead blasted gasket surfaces, cleaned and ready for installation.
IRONDOG is offline
post #6 of 20 (permalink) Old 11-28-2006, 08:51 AM
Where?? What type of machine do you have??
post #7 of 20 (permalink) Old 11-28-2006, 08:54 AM
I just fix 'em...
IRONDOG's Avatar
Clio, Michigan, just north of Flint. I have a KwikWay FWS-II.
Jerry
IRONDOG is offline
post #8 of 20 (permalink) Old 11-28-2006, 05:13 PM
I'm very surprised. I have 4 machine shops around me and they all do small engines.
1999 Ski Doo MXZ600
post #9 of 20 (permalink) Old 11-28-2006, 07:38 PM
Jerry
Kwik-Way is the boring bar, right? What do you use for honing?
post #10 of 20 (permalink) Old 11-28-2006, 07:57 PM
Head horsepower junkie
SSnthe10s's Avatar
Jerry
you dont work at Hardcore do you?
1995 Indy RXL modded....-Sold
SSnthe10s is offline
post #11 of 20 (permalink) Old 11-28-2006, 08:21 PM
ac bigbore's Avatar
boring is cheap- but do they need to be plated?
Going rate is about 40 a hole. As stated in one response,
person doing boring should have new pistons in hand to verify
diameter and clearance. Big question no one asked yet- do they need to be plated? Nikasil will run about 150 a hole.
Several shops do a reputable job plating, I have used
US Chrome in Fond du Lac Wisconsin. They are located in the
Mercury Marine industrial park, and do plating for them.
Good credentials.
Also- if going way overbore, ports may need to be worked over.
ac bigbore is offline
post #12 of 20 (permalink) Old 11-28-2006, 09:44 PM
I just fix 'em...
IRONDOG's Avatar
I have all Sunnen hones, all cylinders are honed vertically under a continous stream of oil.
Jerry
IRONDOG'S Snowmobile Swapmeet Free Ads
IRONDOG is offline
post #13 of 20 (permalink) Old 11-28-2006, 09:49 PM
I just fix 'em...
IRONDOG's Avatar
Um, no.
I work for myself- all I do is powersports engine overhaul. I do cylinder boring, sleeving and crankshaft repair for most all the bike shops in the Flint area.
IRONDOG is offline
post #14 of 20 (permalink) Old 11-28-2006, 09:50 PM
SSnthe10s's Avatar
Um, no.
ahh i see. HArdcore is the only place i know in clio so i thought id ask.
post #15 of 20 (permalink) Old 11-28-2006, 09:55 PM
I just fix 'em...
IRONDOG's Avatar
Hardcore is actually in Mt.Morris township, on Clio road. About 6 miles south of Clio. You have anything done there?
IRONDOG is offline
post #16 of 20 (permalink) Old 11-28-2006, 09:56 PM
SSnthe10s's Avatar
My dad plumbed the Engine dyno. And me and my dad know all the guys up there.
post #17 of 20 (permalink) Old 11-28-2006, 10:40 PM
I just fix 'em...
IRONDOG's Avatar
How did your dad come to do the plumbing on it? I assume you are talking about the water brake and maybe some cooling lines. Just curious.
IRONDOG is offline
post #18 of 20 (permalink) Old 11-28-2006, 10:43 PM
SSnthe10s's Avatar
yea all that stuff.
post #19 of 20 (permalink) Old 11-29-2006, 06:01 AM
Jerry
I'm impressed....that's some good equipment!! Nothin' makes an engine run better, than a round cylinder!! I used to use that same equipment on my kart engines. Do you use any jigs/tools/fixtures to ensure the bore is truly square to the crank? That will also help make HP's!! I'll keep you in mind when the time comes, since you aren't that awefully far from me!!
post #20 of 20 (permalink) Old 12-01-2006, 12:09 PM Thread Starter
yamahog's Avatar
Thanks guys, I only neeed to go 20 over. Freaking oil injection failed. Motor only has 1500 original miles on it. Not bad for a 1984. I think I'm gonna pre mix myself for now on.
Beep, Beep, Richie
yamahog is offline
