secret trick to getting skid bolted back in? - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 16 (permalink) Old 11-18-2006, 02:12 PM Thread Starter
Head horsepower junkie
SSnthe10s's Avatar
OK so i put new rear springs and slides in my sled last night. My problem is i have been fight trying to get the ski lined up to the tunnel bolt hole. The front bolts pirticulary. So anyone have any helpful tips?
1995 Indy RXL modded....-Sold
SSnthe10s is offline
post #2 of 16 (permalink) Old 11-18-2006, 03:18 PM
Mr Polaris
big bore king's Avatar
Tip the sled on its side, with skid in track pull rear idlers until track and skid are 90*, install front bolts. Push skid/track assembly back into tunnel, Tip sled back upright install rear bolts. If you leave the rear springs off the lower slides( no tension on springs) the rear bolts go in a lot easier.
Anything stock pretty much sucks!
2001 Polaris 600xcsp(sks) 1.5 paddle
2002 Polaris 500xcsp 1.25 paddle
1996 Polaris Ultra SP
2000 Polaris XCR 120
2000 Ski Doo Formula 380
2000 Polaris trail blazer 250.
2001 Yamaha Big Bear 400
2000 Honda TRX 90
1995 Jeep Wrangler
2008 John Deere 2520, FEL, snowblower, cab
big bore king is offline
post #3 of 16 (permalink) Old 11-18-2006, 04:13 PM
Proxj's Avatar
get tw people lift it up and bolt it in, ive done 8 skids in the last month.
2002 pro x 600- slp can, handgaurds, 04 prox-r graphics, shorty seat, clear tank, race winshield, 136, 1.25 preditor track, clutched, geared, C&A razors
2003 outlander 400 ho
Proxj is offline
post #4 of 16 (permalink) Old 11-18-2006, 05:04 PM
I always start with the front and work my way back.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #5 of 16 (permalink) Old 11-18-2006, 05:54 PM
95 Indy 500
olskool53's Avatar
I use a ratchet strap to compress the suspension! Goes in real easy! The hard part is getting it out..........one bolt comes out then the other spins the shaft, then your grabbing all 1/8" of the shaft showing with needle nose pliers!
"Just DOO it"
olskool53 is offline
post #6 of 16 (permalink) Old 11-18-2006, 06:58 PM
A god among men
BRPforlife's Avatar
They're only cosmetic, leave them out.
BRPforlife is offline
post #7 of 16 (permalink) Old 11-18-2006, 07:00 PM
upersleder's Avatar
i always start with the fron olted in also. i have used a strap on the rear to compress it before i put it in, then release it to the proper spot and bolt it up.
2003 MXZ 700X
take the warning labels off everything and let the problem sort itself out
upersleder is offline
post #8 of 16 (permalink) Old 11-19-2006, 08:23 AM
ac bigbore's Avatar
olskool 53 has it right- ratchet strap or come-along
I have used a come-along for years for this task. Attach one hook to ski post in front. Already have front bolts in skid. Attach other hook to appropriate point on skid. Pull on come-along bar with one hand and slide rear bolt in with other hand. Have done this by myself many times.
A cheap come-along costs about the same as the 12 pack you will have to buy to get friend to help you.
ac bigbore is offline
post #9 of 16 (permalink) Old 11-19-2006, 10:43 AM
Back Out!
Formula_Canuk's Avatar
Originally Posted by olskool53
Ione bolt comes out then the other spins the shaft, then your grabbing all 1/8" of the shaft showing with needle nose pliers!
Anyone have a fix for that? Last time that took me 3 times longer then getting the friggin track in
96' Formula III 600 triple
02' XCSP 800 edge
Formula_Canuk is offline
post #10 of 16 (permalink) Old 11-19-2006, 10:57 AM Thread Starter
SSnthe10s's Avatar
OK i took seg's advice and unbolted the limit straps and that helped alot. Me and the Girlfriend, man handled it in to position and got the bolts in. Now to just adjust the tension correctly....uhhhhg
post #11 of 16 (permalink) Old 11-19-2006, 11:28 AM
IndianRvrShiver's Avatar
Originally Posted by SSnthe10s
...Me and the Girlfriend man......
OK, SS, we always though you were a little swishy, now you confirmed it!!
IndianRvrShiver is offline
post #12 of 16 (permalink) Old 11-19-2006, 11:44 AM Thread Starter
SSnthe10s's Avatar
HA there! i fixed it.
post #13 of 16 (permalink) Old 11-19-2006, 04:44 PM
rgoers's Avatar
You can do it yourself EASY! I've tried wrestling (didn't like it), and used a ratchet strap (PITA). Here's a better way!
Next time:
Jack the rear up high.
Leave the rear springs *uncompressed*.
Put in front bolts.
Lift rear into position and bolt it.
Compress the rear springs.
It's a piece-of-cake one-man job that way.
2004 Polaris Trail RMK 136
1997 Ski Doo Summit 500
rgoers is offline
post #14 of 16 (permalink) Old 11-19-2006, 04:49 PM Thread Starter
SSnthe10s's Avatar
Next time:
Put in front bolts.
yea thats pretty much what i did. i used my cherry picker to jack it way up in the back. but the thing that did the trick was unbolting the limit strap.
post #15 of 16 (permalink) Old 11-19-2006, 09:12 PM
Cheif wrench at SLM
Fixitguy74's Avatar
The fix is to loosen one side most of the way out and retighten it a little more than finger tight. Then loosen the other side and remove it. The retightened bolt holds the shaft, but should be loose enough to remove easier.
Steve
Second Lap Motorsports race team manager, team mascott, race mechanic and driver. Too bad we don't have a race team. www.secondlapmotorsports.com
Fixitguy74 is offline
post #16 of 16 (permalink) Old 11-20-2006, 06:04 AM
If you don't have an air wrench/inpact driver, take a longer bolt with a locking nut on it. Turn the bolt in enough to hold and use the jamb nut to hold the shaft. Remove other bolt, loosen jamb nut and remove long bolt.
