Old 11-04-2006, 10:40 AM   #1 (permalink)
Snowmobiles
Snowmobiles's Avatar
rear suspension
Ok i had an idea for the rear suspension. I have a polaris and it as the front shock on the rear suspension with the spring over it. The back shock is just a shock, could you put another shock with a spring over it to make the sled sit higher. My brother said you couldn't but i was wonder if you could and if you couldn't why. Thanks
Snowmobiles is offline   Reply With Quote
Old 11-04-2006, 10:48 AM   #2 (permalink)
The suspension is probably at the top of it's movement as it is. Adding a spring probably won't help much.
smallengineguy is online now   Reply With Quote
Old 11-04-2006, 04:51 PM   #3 (permalink)
plyr2k
Up, up, and away!!
plyr2k's Avatar
Adding a spring to the back shock will not do anything because the two springs on either side do excatly what the center spring would do. Some suspentions are made without the two springs and just the one in the middle shock (ie. M-10) but adding a spring will just stiffen the ride alot.
plyr2k is offline   Reply With Quote
Old 11-04-2006, 10:26 PM   #4 (permalink)
rgoers
rgoers's Avatar
The rear skid shock usually has quite a bit of travel. I would think adding a spring would mess up that travel. Not to mention - the manufacturer has the suspension tuned for optimum performance. If adding a spring was a good thing to do, they would have done it already.
2000 440 Panther
1980 Jag 3000 F/C
Old 11-04-2006, 10:37 PM   #5 (permalink)
Snowmobiles
I wanted to make my sled sit higher by not buying a new suspension, how could i do that?That was just an idea for the shock thing off the top of my head.
Old 11-04-2006, 11:11 PM   #6 (permalink)
rgoers
rgoers's Avatar
Could drop the rear mount to a lower hole. Again, that messes up the geometry of the sled's design.
Why do you need it to sit higher?
2000 440 Panther
1980 Jag 3000 F/C
Old 11-04-2006, 11:47 PM   #7 (permalink)
Snowmobiles
I don't need it to it was just an idea that i wanted it to sit a little higher.Hey smallengineguy what did you add to your mach 1 that made it sit higher?Would that make my polaris sit higher?
Old 11-05-2006, 06:30 AM   #8 (permalink)
I swapped the whole suspension out of a 99 Mach Z to my 92.
