10-29-2006, 07:15 PM
another clutch question
I searched around and couldnt find an answer so here it goes. I was going over my sled and cleaning the clutches before the season starts and noticed a lot of clearance between the sheeves of my drive clutch and the belt. I beleive my manual says it should be like 20 thousandths of an inch and mine is more like 1/8th of an inch when you put the belt tight against one of the sheeves. I put a new belt on and it was the same. The sled seems fine and and the clutch engages at right at 4000 rpm like it should. The bushings feel nice and tight but I dont know what could be worn that would cause this. It may be normal like I said it engages like it should.
IAFF 2164
99 RMK 700
97 RMK 500
03 Polaris Sportsman 500
02 Polaris Sportsman 500
05 Polaris Predator TLE 500
10-29-2006, 07:57 PM
If it works OK, the RPM's are right, and it isn't burning belts, I wouldn't overanalyze it.
If you prop the back end, does the track just start to spin at normal idle speeds? It should...
2000 440 Panther
1980 Jag 3000 F/C
10-29-2006, 08:25 PM
Ill have to see if the track moves when its propped up, I really dont think there is any way it could though with the clearance the belt has.
IAFF 2164
99 RMK 700
97 RMK 500
10-29-2006, 08:30 PM
Stupid question... but, are you sure it's the correct belt?
2000 440 Panther
1980 Jag 3000 F/C
10-29-2006, 08:59 PM
It should be, Ill check the part number to be sure. It fits in the driven the way it should.
IAFF 2164
99 RMK 700
97 RMK 500
10-29-2006, 09:12 PM
I looked up the part number and it just shows it fits "Indys", its not model specific. I have always bought belts just by part number and havent given my dealer my model to see hwat they would give me. The number is 3211042. Do you have a way to confirm thats the correct one?
IAFF 2164
99 RMK 700
97 RMK 500
