Hey all,
I'v got a 1994 Arctic Cat Cougar 440 and it runs great, when it starts, Most of the time it starts within a couple pulls but sometimes there is no spark. It shouldn't be freezing somewhere because It was 38 degrees today. Not sure where to start. Sometimes I keep the sled outside. Thanks in advance.
Idk how to check what Kc is talking about. To check the wires inspect them closely to make sure there not cut and exposed etc... I haven't checked coils in awhile someone esle should be able to explain that
Thanks,
I looked at those and they are very helpful. I will probably give that a shot later in the week. One last thought I had was that above the stator/recoil starter, ther is an opening about an inch long, could water be getting in their and shorting it out?
Another question regarding belt tension. How would I loosen the secondary clutch so that the belt sits in a little more? It is too tight so I need to loosen it somehow. (1994 Arctic Cat Cougar 440).
You need to remove the unit from the shaft.
A couple of 4x4 pieces or similar will be helpful to support the movable sheave from underneath.
When you remove the keeper clip and slide the helix [ramps] off the shaft, pay attention to how much the inner part turns [pre-load] when it releases.
When you remove the spring, note which hole the spring is anchored in so you can put it back right.
There will also be some shims on the outer side of the ramp that you do not want to loose as these will be used in between the sheaves.
Note which ones are in the middle and their thickness, add or remove what you need to get the belt height needed.
The reason I wanted to loosen the belt is because it squeels when starting from a stop, the snowmobile creeps along because it is too tight and it makes it kind of hard to start because it is tight. It should be the right belt too. I got it from fleet farm. I looked in the belt lookup and I got the belt number that the book said for my snowmobile.
Everything seems to work for now with some wd-40, but now I have a new problem. (posting a new thread)
Related Threads
Snowmobile Forum
630.8K posts
58.1K members
Since 2002
