Old 02-22-2006, 09:33 AM   #1 (permalink)
||AlpineStars||
||AlpineStars||'s Avatar
Serious problem
well.. i was out riding and when i stopped for a while and then again pulled the throttle and left off.. my sled has some strange sounds.. i now know where the problem is.. It is located in the front there where the Mat is going to the motor.. it seems that the motor can't make grip to the Mat.... does anyone now what it can be? i have a guy that live in my town that habve already fixed my sled once.. he have 6 sleds of his own, i didn''t knew he excisted xD.. PLZ guys help me! :s
Need to go FAAST!!
Yamaha SRX 600 -99
Polaris Indy Trail Supertrak 500 -86
San Remo Quad 250 -04
Renault 1000cc -71
Sunbuster R -91 + Yamaha 30 -99
||AlpineStars|| is offline   Reply With Quote
Old 02-22-2006, 10:00 AM   #2 (permalink)
||AlpineStars||
please answer someone :S:S
Need to go FAAST!!
Yamaha SRX 600 -99
Renault 1000cc -71
Old 02-22-2006, 10:49 AM   #3 (permalink)
BRPforlife
A god among men
BRPforlife's Avatar
You're engine is not gripping the mat????
You're engine is bolted to the motor mounts which are part of the frame!
Are you talking about your drive belt???
It's hard to diagnose when your english isn't too clear! Can you give us anything else?
Old 02-22-2006, 10:51 AM   #4 (permalink)
BC_Dan
Maybe the motor mount is broken? Can you take a picture and post it? That would help people visualize what you are trying to describe...
Rebuilding the fleet!
Old 02-22-2006, 11:14 AM   #5 (permalink)
||AlpineStars||
i can't take a pic... it's hard for me to describe when i can't anything about motors.. belive me, it's not my english! i just can't describe.... When the mat is going to the motor and then back it starts jumping and stuff, moving... then it says k-k-k-r-r-r-r-.. I don't really know what the problem is.. tommorow i guy will look on it. And he also said my sled should have reverse!! i didn't knew that, he said it could be something with the chain, that it had jumped off... Keep on helping me guys :/
Need to go FAAST!!
Yamaha SRX 600 -99
Renault 1000cc -71
Old 02-22-2006, 11:54 AM   #6 (permalink)
BRPforlife
A god among men
BRPforlife's Avatar
GOTCHA!!!! It's your track tension! Your track (not your mat, well I guess you can call it your mat) is too loose and the drive shaft is skipping over the drive cogs on the inside of the track! There should be two adjustment bolts (one on each side) at the back of the sled pushing on the rear bogie shaft. Tighten these bolts until the track is tightened to manufacturers specs. I think it's roughly an inch between the slider and track with 15lbs on the track. After that is done spin the track and make sure it is alligned by looking at the outer cogs compared to the sliders. If one side is closer than tighten that side or loosen the other side (either one will work). If you don't know what I'm talking about I would be happy to take some pics explaining things!
Old 02-22-2006, 12:32 PM   #7 (permalink)
||AlpineStars||
yes plz do!!! i can show the boy that will come here.. so he doensn't make anything wrong thank u so much!!!!
Need to go FAAST!!
Yamaha SRX 600 -99
Renault 1000cc -71
Old 02-22-2006, 12:45 PM   #8 (permalink)
BRPforlife
A god among men
BRPforlife's Avatar
Well there is still a possibility that it is your chain, if something happened with your chain tensioner! But it's most likely your track. The chain skipping will be a loud sharp snapping sound coming from under the hood. The track ratchetting (skipping) will be a loud thunk coming from right underneith you. Here's some pics of the drive cogs and adjustment bolts. Hopefully this will help you learn a little bit about your sled!
This is the drive shaft! It is skipping over the drive cogs.
Old 02-22-2006, 12:46 PM   #9 (permalink)
BRPforlife
A god among men
BRPforlife's Avatar
Here are the drive cogs on the inside of the track that the drive shaft hooks on to in order to move the sled.
Old 02-22-2006, 12:48 PM   #10 (permalink)
BRPforlife
A god among men
BRPforlife's Avatar
Here's the rear bogie shaft that you will have to loosen in order to adjust the track tension (remember to tighten it again when you're done). It slides back and forth making the track tighter or looser.
Old 02-22-2006, 12:50 PM   #11 (permalink)
BRPforlife
A god among men
BRPforlife's Avatar
This is the adjustment bolt. There is one on each side. When you tighten the bolt it pushes the rear bogie wheels against the track making it tighter, you also use these bolts to adjust the allignment of the track.
Old 02-22-2006, 12:53 PM   #12 (permalink)
BRPforlife
A god among men
BRPforlife's Avatar
This is the space between the slider shoe, and the outer drive cogs. This space should be the same on both sides of the track. After making an adjustment to the bolts, spin the track a little and re-check the gaps until they are both the same. Remember that these pics wont be identical to your sled considering the different manufacturers and difference in model and year, but it's the same principals.
Old 02-22-2006, 01:20 PM   #13 (permalink)
80JD440
Nothin Runs Like A Deere
80JD440's Avatar
Wow. I should probably check the tension on my liquifire too. Hasn't been done since new.
80JD440 is offline   Reply With Quote
Old 02-22-2006, 02:07 PM   #14 (permalink)
fr0st
Burn Baby Burn !!
fr0st's Avatar
wha?? it hasn,t been done in the last 26 years??
Fr0st
89' Pantera (mr. brownsled), comet 108 CKK clutch, modified exaust...killed by teflon tape in 2004...caught fire in 2005..top speed 80 MPH (speedo) reading.
00' Kawa zx-9 (Lola,the bitch), K&N filter, Muzzys titanium exaust , -1 tooth on front sprocket and pirelli diablos. speed : enough.
2003.5 Mazdaspeed Protege (waazda) - upgraded SMIC, catless downpipe, boostsciences bov,short ram intake and EBC cross drilled and slotted brakes. speed : 130MPH (limited)
fr0st is offline   Reply With Quote
Old 02-22-2006, 02:20 PM   #15 (permalink)
||AlpineStars||
thank u so much BRPforlife... i will look on it tomorrow the time here is now 21:19 i think i got it all
Need to go FAAST!!
Yamaha SRX 600 -99
Renault 1000cc -71
Old 02-22-2006, 02:22 PM   #16 (permalink)
||AlpineStars||
so this is the only things i have to do if that's the problem?
Need to go FAAST!!
Yamaha SRX 600 -99
Renault 1000cc -71
Old 02-22-2006, 02:22 PM   #17 (permalink)
||AlpineStars||
i don't need to do anything with the driveshaft, right?
Need to go FAAST!!
Yamaha SRX 600 -99
Renault 1000cc -71
Old 02-22-2006, 02:35 PM   #18 (permalink)
Correct. Just tighten the track. Be sure to check the tension after doing high speed runs on the ice as there is little snow to help cool the track and limit the amount of stretching that occures.
Old 02-22-2006, 03:23 PM   #19 (permalink)
80JD440
80JD440's Avatar
Well, I'm assuming my dad has never messed with it. I'm going to check it all out over the summer. But until then, let's hope I don't break anything.
Old 02-22-2006, 04:21 PM   #20 (permalink)
98xc600racer
Need a Avatar that works
98xc600racer's Avatar
Re: ...
Originally posted by ||AlpineStars||
....k-k-k-r-r-r-r-.....:/
Sweet noise! :P lol
Cant touch this. Dun nuh nuh nuh nuh nuh nuuuuh nuuuuh. Ya here that u sh!tty kitty riders?
98xc600racer is offline   Reply With Quote
