anyone have experience with the 89 wildcat.....
i want to unhook it the correct way...i am thinking of just leaving oil in the oil tank and have it feed to the oiler, but blocking off the outlet ports that usually feed oil to the engine, this way if the water pump uses oil, it will still get some....am i thinking this correctly...thanks.
i would rather buy a block off kit, but it appears this engine cannot us it.
from the decription of the block off plate.....
"Oil Injection Cover for Arctic Cat(Reference #AC-OICOVER)
A plate to cover the oil injection pump hole in the crankcase allowing you to remove oil injection system. Fits all 530 L/C and all 1986-90 except Wildcat & 440 LW (Prowler). "
