» Site Navigation
» Power Sports Links
Old 01-25-2006, 07:02 PM   #1 (permalink)
72TNTSkidoo's Avatar
Vibrating Track
Hey well my bros and I got out there again tonight, and it was a blast. But I notice when I waiting in the field, and my bro takes off with the sled, it sounds from afar like loose wrenches in the track. And when your riding it, the sled intermittly vibrates all the way through the seat, kind of like the sound when you go over hard ice, but really when the snow if as soft as a babies bottom. The sled is running mint, and turns and rides mint. Just those sounds have been occurring for atleast 2 straight seasons, just curious to what that might be. Sometimes it makes a dinging sound like a bell too from the engine area.
72 TNT Skidoo
94' Ymha Ovation
95' Ymha Ovation
00 Skidoo Formula
Feb 06': S.O.T.M
2006: S.O.T.Y
72TNTSkidoo is offline   Reply With Quote
Old 01-25-2006, 08:04 PM   #2 (permalink)
Make sure track is tight, also the chaincase is adjusted correctly.
Old 01-25-2006, 08:11 PM   #3 (permalink)
A god among men
BRPforlife's Avatar
How do you adjust a chaincase?
Old 01-25-2006, 08:35 PM   #4 (permalink)
Is there some type of tensioner like on a chainsaw to tighten the chain on the saw?
72 TNT Skidoo
94' Ymha Ovation
95' Ymha Ovation
00 Skidoo Formula
Feb 06': S.O.T.M
2006: S.O.T.Y
Old 01-25-2006, 08:36 PM   #5 (permalink)
rgoers's Avatar
Track alignment too...
2000 440 Panther
1980 Jag 3000 F/C
Old 01-25-2006, 08:45 PM   #6 (permalink)
There should be a bolt somewhere on the case to tighten the chain. Tighten it finger tight, then back it off a little.
Old 01-25-2006, 10:11 PM   #7 (permalink)
BskidooC's Avatar
there will be a bolt with a pin in it take the pin out tighten the bolt as tight as you can with your fingers then back it of until the pin will go back in
Old 01-26-2006, 03:04 PM   #8 (permalink)
thanks guys
72 TNT Skidoo
94' Ymha Ovation
95' Ymha Ovation
00 Skidoo Formula
Feb 06': S.O.T.M
2006: S.O.T.Y
Old 01-26-2006, 04:11 PM   #9 (permalink)
The track may also be loose and jumping the sprockets of the drive shaft.
Old 01-26-2006, 04:17 PM   #10 (permalink)
A god among men
BRPforlife's Avatar
Also make sure your sliders arn't warn all the way through to the rails
Old 01-26-2006, 04:24 PM   #11 (permalink)
Well I did some different test today to see maybe what was up with the sounds the track is making. I took it for a ride, and did some stop and go movements, and thats when the dinging would come from. And on the way home the track was vibrating prety bad, and i know it aint the trail cuz the other doesnt make a noise. So I brought it in the back yard and go the track up off the ground. And one of you said maybe the track aint tight enough and I think thats it, because when the track is off the ground, and still spins at a descent clip, and the tension is more than two fingers, which baffles me because the guys down at Reynolds, said the tension was fine. But still confused about the vibrating noise that shakes the machine a little bit, and the dinging, track tension might just be a whole other different problem.
72 TNT Skidoo
94' Ymha Ovation
95' Ymha Ovation
00 Skidoo Formula
Feb 06': S.O.T.M
2006: S.O.T.Y
Old 01-27-2006, 06:36 PM   #12 (permalink)
winter_man's Avatar
it may also be track tensioner springs i had the same problem with my sled
winter_man is offline   Reply With Quote
Old 01-27-2006, 08:53 PM   #13 (permalink)
did u fix it urself and where might i go to fix that in the track?
72 TNT Skidoo
94' Ymha Ovation
95' Ymha Ovation
00 Skidoo Formula
Feb 06': S.O.T.M
2006: S.O.T.Y
Old 01-27-2006, 09:02 PM   #14 (permalink)
BskidooC's Avatar
if the sprokets are jumpin the track youll now it vibrates terably and is louder than hell
Old 01-28-2006, 04:42 PM   #15 (permalink)
Well looking when i opened the hood, the noise, the bell sound was coming from the chaincase. Coming out of the chain case from the top and bottom are to gold spinning dowel bars that go accross to the belt. In that sequence everyonce and a while thats where the bell dinging would come from.
72 TNT Skidoo
94' Ymha Ovation
95' Ymha Ovation
00 Skidoo Formula
Feb 06': S.O.T.M
2006: S.O.T.Y
