» Site Navigation
» Power Sports Links
Old 01-23-2006, 04:03 PM   #1 (permalink)
waiting for my rebuild...
illwerral's Avatar
Question Kind of an odd question
So today I went for a ride, rode kind of hard, had a good time. About half an hour or so after the ride I went out to start the sled up. It would fire a little bit and sputter a bit and die. So I changed one plug, which had a weaker spark than the other and it fired up and idled nice. I took it for a little spin and it accelerated really nice compared to before. Now I shouldn't be complaining about my sled running well, but it worries me because the last time I did a compression test both cylinders were around 100psi. It normally bogs. I have no clue why it would be so hard to start, and then it would start up and run better than before. My spark plugs are generally dark, and not really brown. This is what they look like now:
ILLWERRAL
To mess up a Linux computer, you need to really work at it. To mess up a Windows computer you simply need to work on it.
illwerral is offline   Reply With Quote
Old 01-23-2006, 04:03 PM   #2 (permalink)
illwerral's Avatar
Second
ILLWERRAL
Old 01-23-2006, 04:04 PM   #3 (permalink)
illwerral's Avatar
And another, since I used three spark plugs (changed one out and left the other)
ILLWERRAL
Old 01-23-2006, 04:05 PM   #4 (permalink)
illwerral's Avatar
The pictures aren't the best but they show the color reasonably well. Before I changed a plug and went for a second ride, both plugs looked more like the first, kind of a golden brown.
ILLWERRAL
Old 01-23-2006, 04:14 PM   #5 (permalink)
Runnin Against The Wind!
SnowRida's Avatar
Did you really ask a question?
SnowRida
Yamaha V-Max
02 MXZ 600
97 Polaris Indy Trail Touring
Old 01-23-2006, 04:16 PM   #6 (permalink)
100PSI on both cylinders would most certainly contribute to hard starting and poor performance. You should have around 120PSI
Goldeneyes is offline   Reply With Quote
Old 01-23-2006, 04:42 PM   #7 (permalink)
illwerral's Avatar
Yeah I did. I was asking if anyone knows why it would all of sudden not want to start, and then when it did start run better than before. Like usually it starts one to two pulls, idles low and bogs until 5000-5500 rpm. After I got it started again it kept its idle at around 2000 instead of 1500, which was odd. When I started riding instead of bogging it just went. Best acceleration I can remember out of the thing. Putting in new plugs has never helped that much before. Instead of a dark color the plugs were more a golden brown.
ILLWERRAL
Old 01-23-2006, 04:46 PM   #8 (permalink)
SnowRida's Avatar
Still, if it starts hard, I wonder if your compression is on the low end. Are you running iridium plugs now?
SnowRida
Yamaha V-Max
02 MXZ 600
Old 01-23-2006, 04:52 PM   #9 (permalink)
illwerral's Avatar
I've tried the iridium plugs, and once I rebuild my engine I plan on using them again. When I said that there's 100 psi in each cylinder, I was saying that it worries me that it would run well. Because I know that's low compression. That's why I'm asking why it might all of a sudden start running significantly better. Sorry for not being more clear in the first place, long day today so I'm kinda tired and not thinking the best...
ILLWERRAL
Old 01-23-2006, 04:55 PM   #10 (permalink)
F.K.A. MOUSE72
ITriumph's Avatar
Judging by the color of the plugs, it looks like they're burning ok. 100psi isn't the best compression, but not the worst. What are the outside temps like? Your sled is jetted for a certain temp range, and it is possible that you were outside that range, but then again your plugs would show that. there's also the possiblity that there's water in your gas.
snow and ice imagery
extended forecast for Alanson
And on the eighth day, god created snowmobiles .
ITriumph is offline   Reply With Quote
Old 01-23-2006, 04:59 PM   #11 (permalink)
illwerral's Avatar
It was kind of warm today, around -5*C. But my sled is fuel injected so it takes care of the jetting automatically as far as I know. Now that you mention it I've been forgetting to put gas line antifreeze in and it was sitting at around a quarter tank for a couple days until I filled up today. I guess the water could cause the hard start, but I don't get how that would make it run better than normal once I got it started?
ILLWERRAL
Old 01-23-2006, 05:51 PM   #12 (permalink)
I am the Walrus
letitsnow's Avatar
it might have been the lack of drygas that made it run better.
My Pics
1999 Arctic Cat ZL 440
1994 SkiDoo Mach 1 583
1995 Honda CR 125R
1982 Camaro w/ 355
Old 01-23-2006, 08:34 PM   #13 (permalink)
F.K.A. MOUSE72
ITriumph's Avatar
what happens is condensation builds inside the tank, and drips down the edges of the tank causing water bubbles in the gas. I'm sure you ride your sled alot, so it won't beable to totally separate. Look at your fuel lines (if clear). See if there are bubbles in it.
Old 01-23-2006, 09:11 PM   #14 (permalink)
illwerral's Avatar
I'll check that out tommorrow. Thanks for the replies!
ILLWERRAL
