Old 01-13-2006, 03:20 PM   #1 (permalink)
WEATHERBY460
Oil Injection Flow?
I just put all new fuel/oil hoses on my sled, and was wondering how long does it takes till oil will begin flowing. No snow, so all I can do is just let it sit idle in the garage. Its been about 5 min, and I still see nothing for oil going thru the hoses....????
Old 01-13-2006, 03:41 PM   #2 (permalink)
big bore king
Mr Polaris
big bore king's Avatar
You need to pull the fuel line from tank off at the pump and put a line in a can of premix gas,start engine let idle, and pull the oil pump cable on the pump like you are at WOT. Then it should bleed right out in about a min. At idle the pump puts out very little and thats why you haven't seen oil yet. and on some machines oil will not gravity feed thru the pump. Hope this helps
Anything stock pretty much sucks!
2001 Polaris 600xcsp(sks) 1.5 paddle
2002 Polaris 500xcsp 1.25 paddle
1996 Polaris Ultra SP
2000 Polaris XCR 120
2000 Polaris trail blazer 250.
2001 Yamaha Big Bear 400
2000 Honda TRX 90
big bore king is offline   Reply With Quote
Old 01-13-2006, 05:45 PM   #3 (permalink)
upersleder
upersleder's Avatar
there also should be a bleeder fitting on the pump, usually just a bolt you take loose to let the air out of the line. make sure you premix the oil in the gas like he said ^^^
2003 MXZ 700X
Old 01-14-2006, 08:31 AM   #4 (permalink)
rgoers
rgoers's Avatar
Hope you're running pre-mix while you're running it. There have been numerous threads on how important it is to have oil injection working properly. A single air bubble can can fry an engine!
2000 440 Panther
1980 Jag 3000 F/C
