Old 01-07-2006, 03:31 PM   #1 (permalink)
doggydon
'02 zl 550 esr won't start no spark?
2002 ZL 550 esr won't start no spark. Coil tested good?
doggydon is offline   Reply With Quote
Old 01-07-2006, 07:00 PM   #2 (permalink)
Did you use a spark tester? Unhook the key/kill/tether switches to be sure it's not one of those. If still no spark, CDI.
Old 01-08-2006, 12:35 PM   #3 (permalink)
doggydon
02 zl 550esr no spark?
thanks for the help. down to the cdi or the stator. does any one know how to test the cdi. what should the readings be???
Old 01-08-2006, 01:27 PM   #4 (permalink)
The stator should be a low ohm reading. Not sure what wires, though.
Old 11-02-2009, 01:41 AM   #5 (permalink)
pinlyztre
pinlyztre is offline   Reply With Quote
Old 11-02-2009, 06:17 AM   #6 (permalink)
You can't test a CDI. only OHM a stator.
Old 11-02-2009, 07:34 AM   #7 (permalink)
kccats
Did you unplug the 4 way and test? then jump the brown/black?
Old 11-02-2009, 07:52 AM   #8 (permalink)
Blaine1
Pretty much the only way to test a cdi is to measure the dc voltage output. The cdi converts ac voltage to dc voltage, tells the spark when to spark and sends the spark to the secondary coils. You have to have a special dc voltage gauge to read output voltage from the cdi due to the fact that the voltage is so "fast" that a normal multimeter can't read it. Out of your whole ignition suystem, the LEAST likely to fail is the CDI. 99 out of 100 times there is another issue from bad coils to bad stator to bad ground to broken/loose wires, bad trigger coil, sheared timing key (when a sled is running bad) ect.. before there is ever a bad cdi. On EFI's their ECU can go bad.
This is how you test a stator and a pulse/trigger coil. Also, check for loose wires, broken wires and bad grounds:
Stator testing out of a sled
YouTube - Stator Testing a 2 Stroke Stator
Stator testing in a sled:
YouTube - Stator Testing in a sled
Stator removal:
YouTube - Installing a Stator Pt.1 Removing it
Stator reinstall:
YouTube - Installing a Stator Pt.2 Putting Everything Back Together
Testing a pulser/Trigger coil
YouTube - Pulser Coil Testing
Wanted: Dead Stators all types for rewinding. PM me.
