New to drag races - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 7 (permalink) Old 12-21-2010, 08:59 PM Thread Starter
prairieboy13's Avatar
New to drag races
I'm new to drag races and was wondering if I could get some tips on what little tweaks I could do to my sled to improve my performance. My hometown is having some drags on the last weekend in January and I'm looking for some bragging right over my buddies, also wondering what classes I should run in. My sled is an '04 Firecat 700, it has an MBRP can as well as lower gears for higher acceleration.
Current sled
04 Firecat 700 efi snopro
prairieboy13 is offline
post #2 of 7 (permalink) Old 12-22-2010, 07:52 AM
Quoted: 143 Post(s)
Studs, lotsa studs!
kccats is offline
post #3 of 7 (permalink) Old 12-22-2010, 09:13 AM
Live To Ride
deezy's Avatar
x2 on studs.
I dont know too much about drag racing but seems to me everyone likes to take out their shocks
I drive a snowmobile
deezy is offline
post #4 of 7 (permalink) Old 12-22-2010, 01:14 PM
For drag racing, crank down the front limiter straps to keep that front end down.
Back off all the springs to lower the sled as much as possible too.
post #5 of 7 (permalink) Old 12-25-2010, 08:41 PM
Quoted: 23 Post(s)
take the can off and put the stock one back on! depending on rules they base their classes on a can will typically put you into an improved/modified class.
if you have the time and money, for that f7 buy yourself a timing advance key. its a cheat thats legal! look at the isr rules.
traction is king, so stud up if you can. suspension settings are a key as well. loosen the preload on the ski shocks and remove the carbides. stiffen up the preload on the front of rear skid shock and loosen the rear of rear. then adjust your limiter straps to pull the front end up and hold about 6" off the ground for the 500' pull.
next would be clutching. you want the secondary to shift as quick as possible without bogging the motor. a shallower angle helix will help. you may have to load the primary a bit on the tip. if you have an option for a softer compound belt, run it.
is your sled injected or carbed? cant remember. those f7's were always a challenge for our yamahas. carbed will require adjustments for the day, temp, and barometric pressure. have jets and know-how.
practice, practice, practice! if you have a spot you can run wfo with a safe shut down area, use it. test the clutching and take notes. a mule sled is your friend at this point, not the 501 dyno. if a set up feels faster to you, its probably not. you need the mule sled for comparison. pace off the 500' and have a timer. watch your tach and speedo, take notes, make changes, repeat.
reaction time. races are either won or lost due to the lack of or ability for. heres the biggest trick for a beginner dragger: enter as many classes as you possibly can. by returning your sled to stock(back to the stock exhaust), you can enter as many classes as your wallet will allow at the 700cc level or above. its perfectly acceptable to run your sled in the 700 stock, improved, modified and then you can bump classes. run the 800 classes as well. i used to run my 600 stock appearing all the way through the open class. never forget the look on the big boys faces when that little well tuned sled would take them down.
so theres a few hints to get started. testing, notes, and practice are your keys to win at this point.
yamadad4 is offline
post #6 of 7 (permalink) Old 12-26-2010, 12:01 AM
^^x2^^
BigAl18 is offline
post #7 of 7 (permalink) Old 12-27-2010, 12:36 AM Thread Starter
Don't have the stock can, but it is not a sanctioned event just a bunch of buddies having some drag races. The sled is injected and not sure about studs, it has 1.75" paddles right now and I am in school right now so money is tight. Haven't done much work on the sled so need some instructions for adjusting the suspension I know how to adjust the rear with the triangle spacer but that is about it. Any tech tips and instructions would be greatly appreciated
Current sled
