Yes, definitely get new bearings if you've already got it taken apart. I blew out the clutch side driveshaft bearing on my 93 xlt 3 seasons ago, the stress from the track pulling back on it caused the driveshaft to drill itself straight back into the tunnel about 2 1/2 inches. Then I had to cut the inner bearing race off of the driveshaft which had heated itself on. Luckily no damage to the chaincase side, but I still replaced both sides bearings and the inner and outer brackets that hold the bearing on the clutch side. I had to rivet some quarter inch alluminum to the tunnel to repair the damage. It could have used a new driveshaft, but I made it work with only the small sacrafice of not being able to hook back up the speedo cable due to damage on the end of the driveshaft. So be sure to get those bearings, and keep them well lubed.
