Old 11-20-2003, 06:07 PM   #1 (permalink)
XmEthEnX
Boring carbs
Hello, How much can you bore carbs? I have a 40mm bored to 42mm, can I go any more?
Thanks
Larry
XmEthEnX is offline   Reply With Quote
Old 11-26-2003, 11:56 PM   #2 (permalink)
Terry
Is there good reason to bore out the carbs? Do you understand fully what the result of this is ? If not, can you afford new ones when you go too far and are not satisfied with the change?
There are limits to everthing and if you are not aware of what the final result will be, you could be in for a surprise when you modify too far. Carb size (jetting, etc) is balanced with the engine and exhaust system to achieve a result. If you like tinkering and experimenting go for it.
Terry is offline   Reply With Quote
Old 11-29-2003, 01:19 AM   #3 (permalink)
sonic340ts
you can bore yours to 44mm...
sonic340ts is offline   Reply With Quote
