Engine bog - Page 2 - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-31-2013, 03:13 PM   #21 (permalink)
Josh Kidner's Avatar
Re: Engine bog
Left looks good, right is too rich. Replace them both. The one prob. Isnt burning it all (weak spark)
Old 01-31-2013, 03:25 PM   #22 (permalink)
Better do a seal test.
Start it up and spray some starting fluid behind the clutch [at the crank stub] and if it revs up, you have a bad seal.
Old 01-31-2013, 04:01 PM   #23 (permalink)
I sprayed some starter fluid as you suggested and the revs stayed the same, should I take it for a spin with different plugs?
crispyzombie is offline   Reply With Quote
Old 01-31-2013, 05:07 PM   #24 (permalink)
Re: Engine bog
Take it for a spin with NEW plugs. Also make sure the plug cap has clean contacts and the wire is tight onto the coil.
Old 01-31-2013, 06:42 PM   #25 (permalink)
OK i just took it for another spin and same thing with the plugs, one fouled and one clean. It seems to run fine, but one thing i noticed was a sound kinda like sucking air that I'm pretty sure wasn't there before.
Old 01-31-2013, 08:09 PM   #26 (permalink)
Crank seal could be sucking air making that cylinder run lean
62k10 is offline   Reply With Quote
Old 01-31-2013, 10:30 PM   #27 (permalink)
I noticed there seems to be abit of sludge leaking from my exhaust gaskets, could an air leak there cause issues like this? Also what about a blown head gasket?
Thanks!
Old 02-03-2013, 01:15 PM   #28 (permalink)
Re: Engine bog
I also had some sludge coming out of my gaskets. I resealed them with high heat gasket silicone and REPLACED THE PLUGS!! It wasnt burning everything and was letting fuel/oil into the exaust
Old 02-18-2013, 02:09 PM   #29 (permalink)
OK i got the sled going well (finally), replaced intake and exhaust gaskets then i tried running it without the air box again... Turns out the airbox was clogging it up abit Has way more power and no bogging
Now i have a question regarding the temps the engine should run at. It has 2 rings that fit under the spark plugs to get the temps. I've had it read as high as 500f when i was pushing it, is that alright or too high?
Old 02-18-2013, 02:46 PM   #30 (permalink)
Head temp gauge!
That's about right, watch and see where it stays most of the time and if it starts climbing out of that range it's time for a cool down.
