need some help!!! - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-11-2013, 05:02 PM   #1 (permalink)
need some help!!!
I was just out riding my sled today. I got a 94 skidoo formula z 583. Everytime I went up a steep hill it seemed Luke the sled was losing power. It would pretty much come to a slow crawl even though you were on the throttle. It also started to overheat to as this was happening. Any suggestions. I have no clue what it could be.
kylemc1987 is offline   Reply With Quote
Old 01-11-2013, 05:15 PM   #2 (permalink)
Have you cleaned the carbs, clutches, checked all fluids including antifreeze, if so have you checked to see if your water pump is working?
mmsrx is offline   Reply With Quote
Old 01-12-2013, 09:21 AM   #3 (permalink)
I hacent cleaned the carbs yet. Clutch looks alrigh. AlAll the fluids are roped off. I'll have to check the water pump tooo. Thanks for the advice Much needed. What's a sled if it can't climb hills.
Old 01-12-2013, 03:51 PM   #4 (permalink)
mabey your thermostat is starting to stick
Old 01-12-2013, 04:40 PM   #5 (permalink)
Do the sharpie test.
Old 01-12-2013, 04:44 PM   #6 (permalink)
This might be a stupid question but what's the sharpie test.
