Occasional power loss - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-06-2013, 05:40 PM   #1 (permalink)
1999 Indy 500 . Carbs cleaned and tuned. Occasionally have to get off sled and help it out by giving it a push or lifting off ground hammer it and jump on fast. Runs great other than that . Any ideas?
Dkinne1993 is offline   Reply With Quote
Old 01-06-2013, 06:53 PM   #2 (permalink)
New plugs?
Old 01-06-2013, 06:58 PM   #3 (permalink)
New plugs ,new gas, sleds been to two shops and still has power loss
Old 01-06-2013, 07:25 PM   #4 (permalink)
Sounds like a belt issue! Clean the sheves and start with a new belt! Get your center to centers right!
Old 01-09-2013, 07:39 PM   #5 (permalink)
Do you notice a difference if it is hot (hot as in you are going through deep snow or working it really really hard) or does it normal driving.
mmsrx is offline   Reply With Quote
Old 01-09-2013, 07:53 PM   #6 (permalink)
meburdick's Avatar
What RPM does the clutch engage at?
Old 01-09-2013, 08:05 PM   #7 (permalink)
No really just gettin going . For example on ice the other day I just put feet on ice and opened up then jumped on. Need to drive hard ! Did notice plug cap was loose on wire and retightened. Possibly it?
Old 01-09-2013, 08:07 PM   #8 (permalink)
Not sure about rpm
Old 01-09-2013, 08:09 PM   #9 (permalink)
meburdick's Avatar
If you're engaging below 4000, the spring in your primary could be worn. If you're engaging below 3000, the spring could be broken.
You could also have poor adjustment of the secondary, a worn belt, or even the wrong belt.
Old 01-10-2013, 05:32 PM   #10 (permalink)
Start your sled up in the dark and look around the plug caps to see if they are arcing to the head. If it has choke pucks on it make sure you have them adjusted with the proper play and they are sliding freely.
