1993 pantera with efi problems - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-05-2013, 09:34 AM   #1 (permalink)
A 1993 arctic cat pantera that I'm doing some work on seems to load up the clutch side cylinder if the fuel pump is allowed to cycle through completely... If you just turn the key on and start it rite up it runs fine.... Has me a little puzzled!!!! Anyone got any ideas???
Mwroberts2012 is offline   Reply With Quote
Old 01-05-2013, 01:12 PM   #2 (permalink)
Possible that the injector is leaking under pressure.
Easy to check, pull the injector out and turn on the key and look for any fuel spray.
Old 01-05-2013, 05:37 PM   #3 (permalink)
Also could be fuel presure?
Old 01-05-2013, 07:26 PM   #4 (permalink)
so there should be no fuel until the sled is actually cranked over correct? if there is then the injector is bad?
Old 01-05-2013, 08:08 PM   #5 (permalink)
Unless it happens to be on that cyl to fire!
If need be here is the guys number that cleans the injectors! Brads A/C Performance
(866) 427-2775
Old 01-05-2013, 08:19 PM   #6 (permalink)
just turning the key to the on position will still spray into the cylinder without it actually being turned over? im not all that familiar with efi..... have mostly worked on carburated models in the past
Old 01-05-2013, 08:34 PM   #7 (permalink)
Its very simple! There is a triger on the flywheel and it will triger each injector individualy at the best time for fuel to be atomized! And there are several sensors to determin hot much fuel it needs!
Old 01-06-2013, 05:18 AM   #8 (permalink)
That is unless the injector is stuck in the open position in which case it will spray as soon as the pressure is sufficient.
