99' Polaris indy 500 won't run
Not sure if this is the correct spot for this thread or not but,,
Alright so i finally decided to get into snowmobiling and already having problems. I bought a 1999 Polaris indy 500 over the summer and after cleaning the carbs and changing the in tank fuel line it was running. Now after a little lite riding it quit and doesn't seem to want to start or run.
The only way to get it to start is to put a little bit of pre-mix down into the cylinder. Even then it will only run for a second then it dies, also tried filling the carb bowls and then start it, even then it only runs for a minute or two then dies. When i take the bowl back off it's empty. Thought it was a fuel issue so took the fuel lines off the carbs and ran them into a bottle and seems to be lots of fuel coming out of the lines.
Thanks for any help in advance.
