Arctic Cat Drive Belt Issues
Hi all! I have a 2001 Mountain Cat 600 EFI That I used for one season with no problems. After missing last year's riding season I fired up the sled and it would not go forward. Also strong rubber smell and smoking. I replaced the belt with a new part (#0627-020) and lifted the track to test. It ran fine with no problems but when I drop it down it does the same thing. I removed the belt and cleaned the clutch and this time I went about 20 feet. After stopping, I have the same issue no transferr of power to the track.
Any suggestions on where to start? I do have a rubber build up on the main clutch flanges that I can remove also, I plan on greasing the track components even though I can spin the track secondary clutch by hand.
Thank you in advance?
