02 edge 800 mods - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-04-2012, 06:08 PM   #1 (permalink)
02 edge 800 mods
Hi any input would be handy i have a 02 edge 800 all stock and wanted a little more topend to beat my buddies arctic cat 800 efi. I want mods that dont take away reliability and not messing up he carbs with jetting and stuff just dont want to open them up and change stuff cause it runs great just cant let him beat me. Thanks
Jmiller12 is offline   Reply With Quote
Old 12-04-2012, 06:57 PM   #2 (permalink)
If you don't want to open up the carbs to change jetting, your options are limited. Best bang for your bucks would be an after-market pipe/can. SLP stuff works great in Polaris sleds. Their single pipe/can will dump a bunch of weight, too. But that will also require rejetting and different springs/clutch weights/helix to take advantage of the pipe. Pretty much if you significantly change one thing, you have to change the others, too.
Twin pipes will give you more HP, but are very touchy to jetting. If you don't want to change jets for riding conditions (elevation and temperature) twin pipes probably won't work for you. That said, an Edge 800 with 160 HP is pretty dang fast and would be very competitive with that 800 EFI Arctic Cat.
If you don't want to do any carb/clutch work, best you can do is to make sure the track is aligned, skis are aligned to the track, no sticky bearings in the suspension wheels, carbides are straight, clutches are clean and clutch offset is spot on. A new belt can also give you a bit more performance, as well.
Old 12-04-2012, 07:02 PM   #3 (permalink)
Thanks alot im not totally against pipe or clutch work im just not very good with the gearing or different clutch parts or stuff like that but i dont want a loud sled either
Old 12-04-2012, 09:42 PM   #4 (permalink)
I had an SLP pipe/can on my 02 800 RMK. It's not loud, just different. It's got a more "throaty" sound than the stock pipe. You can definitely tell it's not stock, but it doesn't split your eardrums when you pin the throttle to the bar. When I got mine, I followed SLP's recommendations to the T for clutching, weights, helix angle, and carb jetting. I never had any issues with any of it, their recommendations were spot on.
That sled was a rocket to about 90 mph. Having up to 150 Hp on tap can be quite addicting
Old 12-05-2012, 07:19 AM   #5 (permalink)
Now that i look at a picture of the slp single can that goes with the stock silencer it might have one on it. Are they alot different than stock how could i tell
Old 12-05-2012, 08:30 AM   #6 (permalink)
Polaris650freak's Avatar
Stocks have a heat shield and slp doesn't and generally says slp on it. The full slp system does wonders on the 800
Old 12-05-2012, 10:28 AM   #7 (permalink)
Get the air box mod too. And add a couple of vents in the dash to let more air in. And Vforce III reeds. The list is endless Let your pocketbook be your guide
Old 12-05-2012, 11:25 AM   #8 (permalink)
I put the whole slp kit in my pro x. Included air box (air horn) kit. 2 dash flo rite vents. Than 2 snow eliminator per filter screens than go on hood right by console. I had to jet up 2 sizes when I did that. I run the boyesen reeds in mine
Old 12-05-2012, 02:25 PM   #9 (permalink)
Could i send pics to one of your email cause my airbox has the big hole in the top and looks like intake horns maybe and the exhaust
Old 12-05-2012, 02:37 PM   #10 (permalink)
Sled187@yahoo.com
Old 12-05-2012, 03:30 PM   #11 (permalink)
Your stock pipe is ceramic coated by the looks of it , you can see the old heat shield hose clamp guides. and the blue vents in front of hood are just a accessorie. They all have them but you can change colors. The air box is stock also
Old 12-05-2012, 03:34 PM   #12 (permalink)
Old 12-05-2012, 03:44 PM   #13 (permalink)
Thanks that helps alot now i know what i have and my options thanks everyone
Old 12-06-2012, 10:41 AM   #14 (permalink)
92 Polaris 550's Avatar
Try going up a tooth on your top gear in the chane case, or some secondary clutches can add a little to your top end,pipes will give a little more go juice also
92 Polaris 550 is offline   Reply With Quote
