Xlt 600 Help
2K views 7 replies 7 participants last post by  dondomman
#1 ·
#4 ·
First thought is lean bog caused by plugged pilot jets. Are the carbs spotless? Is it better if you apply the choke?
Second thought is a fouled plug, my 650 sounds like that when it fouls one. Check for spark as SonofIrishman suggests. It could also be a bad plug wire/plug boot.
How's the compression?
