With your engagement That Low, replace the spring, check the arms and bushing! Do that first before you gear down! And clean them both with a scotch bright or sand paper and blow them out real good! Check the center to centers, and double check that the belt is good and is rideing out of the secondary atleast an 1/8"-3/16"!
