While rebuilding my chaincase before the snow hits, I checked my gear alignment and noticed the bottom gear is significantly pushed "in" [towards the engine]. The chain had been falling off a lot, and I'm assuming it was due to this in addition to a few broken chain links. The bottom [drive] gear is misaligned around 1/8" to 3/16".
Should I shim it? Stock gearing.
Or, could it be that my drive shaft is pushed too far the other way due to bearing replacement on the opposite side? Ugh
ANY help or input greatly appreciated.
