93 xlt 580 no spark? - Snowmobile Forum: Your #1 Snowmobile Forum
Old 10-28-2012, 12:22 PM   #1 (permalink)
Custom580's Avatar
I replaced the stator and it still doesnt have spark. What could be the reason for no spark? What could I test or replace?
Sent from my SGH-T959V using Snowmobile.com App
Custom580 is offline   Reply With Quote
Old 10-28-2012, 06:12 PM   #2 (permalink)
ridegreen's Avatar
What about the coil? Look at all wires and connections
Old 10-28-2012, 06:53 PM   #3 (permalink)
Custom580's Avatar
I looked to make sure connections are connected. But I have to check them still. I dont know what to use
Old 10-28-2012, 08:34 PM   #4 (permalink)
ridegreen's Avatar
Ome meter,
Old 10-28-2012, 08:39 PM   #5 (permalink)
Custom580's Avatar
It doesnt have spark on any cylinder so are all three of the coils conected to each other. I looked and it looks like it
Old 10-28-2012, 08:52 PM   #6 (permalink)
ridegreen's Avatar
That's where I would start
Old 12-12-2012, 11:06 PM   #7 (permalink)
Custom580's Avatar
so i replaced a coil and nothing. there is a little box under the hood on the other side of the little tool box under where the hand wormer is. it has two wires and i followed them to my wiring harness and im not sure what that little box is. its a little square box that has two nuts and two wires connected to it. idk what it is for thought. any ideas?
Old 12-13-2012, 01:13 AM   #8 (permalink)
ridegreen's Avatar
Can you post a pic?
Old 12-13-2012, 01:37 AM   #9 (permalink)
Here's a link to the Polaris website. It shows diagrams of your sled. From your description, it sounds like you are talking about the voltage regulator, which won't have anything to do with spark in the plugs; those two systems are separate.
Browse
Old 12-18-2012, 03:15 PM   #10 (permalink)
This might sound dumb but I did the same thing last night when rebuilding my sled, so if you haven't eliminate the kill switch, key switch and throttle positioning sensors as variables.
dondomman is offline   Reply With Quote
Old 12-18-2012, 11:16 PM   #11 (permalink)
Custom580's Avatar
can i just disconect my kill switch or what do i have to do to test it
Old 12-19-2012, 12:27 PM   #12 (permalink)
Just disconnect everything going to that block your throttle and kill switch is on. Id leave your key hooked up so you have something to turn it off just in case. And then disconnect the key switch and leave just the kill switch hooked up to test the key switch.
Old 12-20-2012, 11:06 PM   #13 (permalink)
Custom580's Avatar
i checked. still nothing. im gonna replace the stator again and see what happens
Old 12-21-2012, 09:07 AM   #14 (permalink)
ridegreen's Avatar
How's the magnets look on the fly wheel? None are broke, cracked or missing? I would clean them up while your in there
Old 12-21-2012, 09:18 AM   #15 (permalink)
ridegreen's Avatar
At this point I would seriously start looking at the cdi box, getting it checked out or swapping it out with another one if possible just to see. You've done everything right so far and still come up empty and ppl say cdi's either work or they dont. I'd my self would de looking into that because you never know and just to be able to say you already did that and move to the next thing.
Old 12-21-2012, 09:27 AM   #16 (permalink)
I agree C.D.I.s tend to work till they warm up and then cause the sled to run like junk. If you've done everything else that's all there's left to do.
