Ski Doo Cylinder Troubles - Snowmobile Forum: Your #1 Snowmobile Forum
Old 10-14-2012, 03:55 PM   #1 (permalink)
Hi1. I have a 1999 Ski Doo MXZ 600 with Rotax Engine. Piston got wiped out by loss of oil. There is aluminum from the piston smeared on the cylinder wall. Are these Rotax Cylinders Boreable? Will honing remove the aluminum from the wiped piston? Not sure what to do. The cylinder doesn't seem gouged just has aluminum from piston on it. I have a honing tool. Should I try honing and replacement pistons or do I need to send out the cylinders for boring and oversized piston?? Thanks. Ken
cobrajetken is offline   Reply With Quote
Old 10-14-2012, 04:08 PM   #2 (permalink)
Rczr600rider's Avatar
I'm pretty sure thats a plated cylinder, so you wouldn't want to hone it, but a machine shop should be able to resleeve it for you. The sleeve should be around $100 or so. Labor could vary depending on where it's done.
Rczr600rider is online now   Reply With Quote
Old 10-14-2012, 07:46 PM   #3 (permalink)
I rebuilt a buddies 600 last year and was able to remove the aluminum with Muriatic Acid and a cotton swap. I honed both cylinders, new pistons and rings. Got 115 psi out of the cylinders and did over 2000km on the sled last year. Hope that can work for you.
pcontant is offline   Reply With Quote
Old 10-14-2012, 07:57 PM   #4 (permalink)
aduck's Avatar
You were at 115# after rebuild?
93 mach1 670
02 rmk 800 162
95 powder special 580
Old 10-14-2012, 08:19 PM   #5 (permalink)
Good catch! 135psi but I'm not sure how accurate my compression gauge is in the first place.
Thanks.
Old 10-14-2012, 08:52 PM   #6 (permalink)
aduck's Avatar
That sounds better. Ya I got 2 testers to keep em in check lol
93 mach1 670
02 rmk 800 162
Old 10-15-2012, 05:40 AM   #7 (permalink)
He's right above. Muratic acid will take the aluminum off the cylinder wall. LIGHTLY hone it afterwards and you're all set.
1999 Ski Doo Grand Touring
Old 10-15-2012, 06:30 AM   #8 (permalink)
Thanks to all.
Old 12-04-2012, 10:37 PM   #9 (permalink)
Sure its lack of oil?Stuck thermostat will stick one cyl and other looks perfect...99 mxz 600 has cast cylinders i believe.
minisrint521 is offline   Reply With Quote
