small oil tank on 98 skidoo mxzx 440? - Snowmobile Forum: Your #1 Snowmobile Forum
Old 07-30-2012, 10:04 PM   #1 (permalink)
travis
Indy92's Avatar
im just wonderin what it is and why it's there. the only thing I can think of is to send oil to lub the crank bearings or something. it's only about an 8 oz tank. I don't work on skidoo's much at all I'm fixing it for a buddy. I work on polarises alot and never seen one. he said that he puts oil in there and it drains in five minutes when it's running. any thoughts? thanks
Indy92 is offline   Reply With Quote
Old 07-30-2012, 11:37 PM   #2 (permalink)
Terrain Dominator
JD8345RT's Avatar
I believe that's what they call oil injection.
1993 Polaris XLT Special
1972 Arctic Cat Panther
Old 07-31-2012, 03:46 AM   #3 (permalink)
It's the tank for the rotary valve to keep it lubed, and it should NOT be emptying out at all.
Old 07-31-2012, 01:19 PM   #4 (permalink)
travis
Indy92's Avatar
what would cause it to drain so quickly. the pump is bad possibly?
Old 07-31-2012, 04:45 PM   #5 (permalink)
A bad seal on the rotary valve shaft would cause it to use up the oil too fast.
Old 07-31-2012, 06:46 PM   #6 (permalink)
travis
Indy92's Avatar
this engine has reeds. I'm confused. damn skidoo haha
Old 07-31-2012, 06:53 PM   #7 (permalink)
travis
Indy92's Avatar
the line from the reservoir goes straight into the crank case right under where the jugs bolt on
Old 08-01-2012, 04:01 AM   #8 (permalink)
I looked at www.hlsm.com and looked up your sled, and it says it has a rotary valve...
Old 08-01-2012, 03:45 PM   #9 (permalink)
travis
Indy92's Avatar
it's possible that someone swapped the jugs at some point to ones with reeds?
Old 08-01-2012, 03:46 PM   #10 (permalink)
travis
Indy92's Avatar
cause this engine definetly has reeds
Old 08-01-2012, 05:31 PM   #11 (permalink)
travis
Indy92's Avatar
ok I figured it out it was made in oct of 98 which makes it a 99 model my buddy went by that and told me it was a 98. anyways it has an internal oil pump and it lubricates that shaft which also runs the water pump. so now I have a job for myself splitting the case and replacing those seals and bearings possibly
Old 08-01-2012, 10:26 PM   #12 (permalink)
travis
Indy92's Avatar
the center mag side seal on the crank was bad told him to get a new engine
Old 08-02-2012, 04:02 AM   #13 (permalink)
That sucks. Very common problem on that generation MXZX's.
Old 08-02-2012, 05:03 PM   #14 (permalink)
travis
Indy92's Avatar
ya I don't think you can buy those seals but still if you could I'd have to find someone to press apart the crank. I told him it would be easier to just throw in a new motor. plus the case is a pain in the rear end get apart and I don't have a clutch or a flywheel puller for a rotax to swap the crank out
