john deere sprintfire electrical
Hello to all......
I'm new to the site and need some JD assistance. I wrecked my JD Sprintfire and decided to throw the engine into my Honda Odyssey.
The engine is the 340 liquid cooled Kaw engine with a comet 102c clutch.
Here's my problems.....
A) How would I hook up a battery to the stock JD wiring system, everything is there but it DID NOT have a battery in the sled.
B) I'm running a 12v DC cooling fan on the radiator from an ATV. Do I need anything in line to protect the system, other than a low amp fuse, or can I tap into any 12v DC wire, like the hot wire to lighting switch? One guy said I should have a relay in the line for the fan but it only draws something like 3-5 amps.
I've been informed that I could burn out the CDI or stator if this is not done right.....I don't want to toast the stator, that's for sure!
Any help would be greatly appreciated!!!!!
