polaris driveshaft? - Snowmobile Forum: Your #1 Snowmobile Forum
Old 05-09-2012, 02:26 PM   #1 (permalink)
polaris driveshaft?
I'm sure the answer is already in these forums somewhere but I'm having trouble figuring out which words to search for.
I have a 2005 fusion that wont move. When the throttle is first pushed it wants to go and starts to move a little. Then it feels and sounds like something all of a sudden just strips out.
The sound seems to come from the around the bottom of the chaincase or lower.
I can lift the track, it spins freely and continues to make a metal on metal noise.
I took video of it but it sounds slightly different in person.
2005 fusion 900 noise - YouTube
any info to help figure out what this is is appriciated Thanks
fusion866 is offline   Reply With Quote
Old 05-09-2012, 03:37 PM   #2 (permalink)
Chain is too loose or stretched out due to lack of lube.
Old 05-09-2012, 06:30 PM   #3 (permalink)
Bone dry. Thank you so much!
Old 05-09-2012, 07:06 PM   #4 (permalink)
TRH- Troll Raising Hell
JheLrey's Avatar
Damn! Never ever seen one that dry...
I would put new gears and a new chain on. Prob. a tensioner while I was at it. Also, check the bearings because those have also been ran dry unless they are sealed in which case you would be lucky.
Snow: The other white drug!
Old 05-10-2012, 07:31 AM   #5 (permalink)
JheLrey's Avatar
Better check your chaincase as well! Metal on metal is only in that area.
Old 05-11-2012, 06:53 AM   #6 (permalink)
ZR rider
TwinsofMLB's Avatar
Note: refill to polaris specifications! You won't need much oil in there because the chain does the work of slinging it throughout the case.
Old 05-11-2012, 08:05 AM   #7 (permalink)
ride till your broke
Renagade's Avatar
my friend mark bought a new rush in 2010, after first
ride he wanted me to check it out, didnt have any
lube in chain case.
so i always check everything!!!!! even when new.
current sleds
04 rev800ho gade
95 formulaIII 600
77 olympic 340e-mint!!
Old 05-12-2012, 09:20 PM   #8 (permalink)
I would even go as far as to replace the bearings as well as both sprockets and chain! And about 8oz of oil!
Old 09-17-2012, 10:03 AM   #9 (permalink)
This brings back bad memory's for me .I Was riding my poo about 2 yrs ago in a field by my house an out no were i hear this grimding noise when l let off the gas. I though may be it was my belt so i check my belt looks .fine i hit the gas an she froze one .my chain case slef destructed its self .new case houseing gears cahain an jack shaft wasent cheap .
diffusion is offline   Reply With Quote
