throttle cable and oil injection - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 8 (permalink) Old 02-24-2005, 08:54 PM Thread Starter
rob0781's Avatar
My throttle cable feels like it needs some adjustment,it's hooked to the oil pump also so if i adjust the throttle cable do i have to adjust the oil pump to be sync'd with the carb?i don't wanna play around with the throttle cable and richen or lean out my machine...any help?
rob0781 is offline
post #2 of 8 (permalink) Old 02-24-2005, 11:08 PM
I gotta have more Cowbell
Jace's Avatar
Work with the carbs first, and then worry about the pump.
Warm up your engine, set the idle. Adjust your throttle cable so that it does not have too much play. (I don't have the proper procedure for that- maybe your manual indiactes something.)
If you are going to sync your carbs this is a good time to do that.
After all that, check your oil pump. There will be a moveable lever arm that the cable attaches to. Near the pivot point of the arm will be an index mark (line or dot). Also, on the body of the pump will be another index mark. You will need to lign these marks up at either idle (or full throttle - depending no your application). If they are not ligned up at either idle or full throttle, you will need to adjust the cable to make it lign up. Adjust the cale going to the oil pump - there should be some jam nuts.
Good luck. -Jace-
Jace is offline
post #3 of 8 (permalink) Old 02-25-2005, 06:57 AM
Is there too much slack in the cable?
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #4 of 8 (permalink) Old 02-25-2005, 01:30 PM Thread Starter
rob0781's Avatar
yeah the throttle feels like it pushes to easy and fels like its not opening fully..
rob0781 is offline
post #5 of 8 (permalink) Old 02-25-2005, 04:05 PM
There should be 1/8 inch of "free play" at the throttle lever before the carb slide starts to move.
1999 Ski Doo MXZ600
post #6 of 8 (permalink) Old 02-25-2005, 04:45 PM Thread Starter
rob0781's Avatar
Ok i'll check for the free play,if i take the airbox off and look in the carb and push the throttle wide open should the slide move all the way up?
rob0781 is offline
post #7 of 8 (permalink) Old 02-25-2005, 05:51 PM
Not completely.
1999 Ski Doo MXZ600
post #8 of 8 (permalink) Old 02-25-2005, 06:01 PM Thread Starter
rob0781's Avatar
maybe it's fine then sleds are new to me so i'm not sure,just going by what a friend says,he said it seems like it's not adjusted right and its too easy to push but he has old sled from the 70's so maybe he's used to those,i can squeeze it and get up over 100km/h no problem so it seems right to me.
rob0781 is offline
