No spark on one cylinder - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 11 (permalink) Old 02-08-2012, 12:24 PM Thread Starter
I have a 97, 440 bearcat. After a good carb cleaning and some seafoam it was running good and i got to say "I told you so to the wife". Then it started spitting and sputtering a bit. I lifted the hood and pulled a plug wire off and nothing happened. I put the wire back on and pulled the other wire off and the machine died. I put the wire back on and high tailed it home.
From what i have found i should start with cutting off 1/4 inch of the plug wire. What would you recommend if that doesn't fix the problem?
Thanks for your imput.
onegunsmith is offline
post #2 of 11 (permalink) Old 02-08-2012, 01:54 PM
ZR rider
TwinsofMLB's Avatar
You haven't proved it's the spark yet. Take the plug out, plug it in the coil, ground it to the motor, and pull it over (best in poorly lit area).
TwinsofMLB is offline
post #3 of 11 (permalink) Old 02-08-2012, 11:44 PM Thread Starter
You're right! Hadn't thought of that. That cylinder may not be getting fuel. Could the fuel pump not be pumping to both sides?
thanks
post #4 of 11 (permalink) Old 02-09-2012, 04:10 AM
OR one carb might have a bunch of crap in the bowl. All you need to do to test spark is swap plug wires. If the cylinders change, then it's a spark problem. If not, look at the carb.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #5 of 11 (permalink) Old 02-09-2012, 06:49 AM
Quoted: 143 Post(s)
Always clean the carbs every preseason! And pay special attention to the pilot jet up the tube!
kccats is offline
post #6 of 11 (permalink) Old 02-09-2012, 11:17 AM Thread Starter
The carbs were cleaned well and a good dose of Sea Foam was dumped in the tank. Rode the sled on a few short hops and replaced some fuel lines. Went on a 40 mile trip and the machine was as good as a 40 mile ride can be on a 97 bearcat can be. Went to go on a short ride with the daughter and the machine started to struggle. Do you think maybe some gunk came lose in the carbs? When I get home I'll swap the plug wires and see whats what.
Thanks
post #7 of 11 (permalink) Old 02-09-2012, 01:00 PM
ZR rider
TwinsofMLB's Avatar
Did you ever drain the old gas and replace it?
post #8 of 11 (permalink) Old 02-09-2012, 01:39 PM Thread Starter
I did drain the gas at the beginning of the season.
post #9 of 11 (permalink) Old 02-09-2012, 08:51 PM
Let us know how you make out on the plug wire swap.
1999 Ski Doo MXZ600
post #10 of 11 (permalink) Old 02-09-2012, 08:59 PM
Quoted: 143 Post(s)
And a compression test at wide open throtle as well as plug color may tell us something?
kccats is offline
post #11 of 11 (permalink) Old 02-09-2012, 09:58 PM Thread Starter
I get home friday, so il let you know what i find. Thanks for all your help.
