Straight piping? - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 10 (permalink) Old 06-06-2011, 11:01 PM Thread Starter
Live To Ride
deezy's Avatar
Straight piping?
Hellooo.
Starting my summer project shortly, and its going to be a drag sled.
I just have a question about straight pipes because I realize that many many drag racers set up their sleds with nothing but a 2-3 inch diameter pipe directed to the side as the exhaust pipe, one for each cylinder.
what are the gains if any of doing this to a drag sled?
is it bad in any way?
might be a dumb question but Im not going to try and make some without a real reason, lol
thanks
I drive a snowmobile
deezy is offline
post #2 of 10 (permalink) Old 06-07-2011, 02:29 AM
Quoted: 101 Post(s)
Straight pipes on a two stroke can be dangerous to the engine. Because of the design of the engine, the intake ports and the exhaust ports in the cylinder are both open when the piston is at bottom dead center. Some of the unburned fuel actually enters the cylinder and exits with the exhaust gas, but because of the length and shape of the pipe, at the exact moment the raw fuel/air is leaving the cylinder, a pressure wave rebounds from the restriction in the pipe and shoves the fuel back into the cylinder to be burned.
If you have a straight pipe, there will be no rebound and your air/fuel mix will be lean, which could cause excessive heat and melt holes in the pistons. If you make the fuel mix rich enough to be safe, your fuel mileage will go south, and your emissions will go up. You will also have really lousy performance at lower RPM. Carbs are designed around the tuned pipe, it will take you a long time (and probably a few rebuilds) before you find jetting requirements to keep the engine safe and still give power.
A tuned pipe eliminates all that and gives you more power to boot, as all the air/fuel mix is burned with no waste.
BC_Dan is offline
post #3 of 10 (permalink) Old 06-07-2011, 04:45 PM Thread Starter
Live To Ride
deezy's Avatar
Thanks Dan once again!
Yeah, I wasnt sure but it did feel like straight piping would feel sort of 'wrong',
I just wanted to check because it would have been nice to have at least one freebie component to the sled! haha.
Ive also seen people running twin/tripple pipes but without the stingers, is that just as bad? or sort of like a half way type of thing?
deezy is offline
post #4 of 10 (permalink) Old 06-08-2011, 12:56 AM
Quoted: 101 Post(s)
There may be a bit of benefit from stingers, but would be easy to tune around (if there was.) The stinger mostly muffles the sound a a bit. Without stingers, a sled would be uncomfortably loud! Noise is not important when drag racing, wear hearing protection
BC_Dan is offline
post #5 of 10 (permalink) Old 06-08-2011, 04:25 PM
Dan, stingers are the small tips on the ends of the pipes, silencers are a packed attachment or open box attached to the end of the pipe outlet.
post #6 of 10 (permalink) Old 06-08-2011, 06:22 PM
Quoted: 140 Post(s)
Stingers are the same as the silencers.
kccats is offline
post #7 of 10 (permalink) Old 06-14-2011, 08:08 PM
Polaris All The Way!!!
cam615's Avatar
krikey where do you learn all this?
cam615 is offline
post #8 of 10 (permalink) Old 06-15-2011, 01:06 AM
Quoted: 101 Post(s)
I stayed at a Holiday Inn Express
BC_Dan is offline
post #9 of 10 (permalink) Old 06-15-2011, 07:39 AM
Quoted: 140 Post(s)
And Years and Years of failures! Personally I've been sledin since 69-70! Been wrenchin since 72!
kccats is offline
post #10 of 10 (permalink) Old 06-15-2011, 11:10 AM
eli346's Avatar
Does that mean you didnt have to fix your sled for 2 years?!
1989 arctic cat jag afs 440(small project)
1990 yamaha phazer 2
The new money pit
eli346 is offline
