Old 10-28-2003, 10:36 PM   #1 (permalink)
Bezz
Bezz's Avatar
Air Silencer
I am fixing up an older ski-doo, 76 440 T'NT, and I keep seeing warnings about the neccessity of the air silencer. Is this a load of crap or is there a reason?
Bezz is offline   Reply With Quote
Old 10-29-2003, 04:30 AM   #2 (permalink)
BoooM
Rider
BoooM's Avatar
Air silencer, is that the same as silencer. In that case YES it's very important. The pipe will reflect unignited fuel back in to the cylinder(s) and wether that should work there must be a precise resistans in the pipe, if you remove the silencer it will not work properly and it will sound terrible. The exhaust system is one of the most important things in a two stroke engine.
Pain is temporary, but glory is forever
BoooM is offline   Reply With Quote
Old 10-29-2003, 04:10 PM   #3 (permalink)
Maverick
Team Arctic
air silencer and silencer are completely different things. you are right about the silencer, but the air silencer will also be needed being that thats where the air comes from for your carbs.
Maverick is offline   Reply With Quote
Old 10-29-2003, 11:21 PM   #4 (permalink)
Bezz
Bezz's Avatar
I keep seeing bolt on cone type filters for carbs, could I just use one of those?
Old 10-30-2003, 04:36 AM   #5 (permalink)
BoooM
Rider
BoooM's Avatar
Aaah OK But why would you remove the air silencer? To reduce wieght?
Old 10-30-2003, 11:49 AM   #6 (permalink)
Bezz
Bezz's Avatar
Because if I have the cone filter on the air silencer can't attatch to the carb!! I think I might make a ram air type setup
