Old 10-19-2003, 02:33 AM   #1 (permalink)
RMK'er
RMK'er's Avatar
Question CARB tuning after V Force 3
sugpiaq_alutiiq@hotmail.com
Last year I replaced my stock reeds with V Force 3's. I've got good midrange but sloppy idle. My main jets (Keihin carbs) are 180's. I didn't replace the needle jets and didn't mess with the needle setting. I've adjusted my airscrews at quarter turns but that didn't seem to have any effect. I'm riding at 0-3000 ft, 10 to -20 degrees. What can I do to improve my choppy idle? What do you suggest if I improve my stock silencer to a Rumble Pack or DG?
SPLIFFIN-ON-TOP-O-DA-WORLD-MON
RMK'er is offline   Reply With Quote
Old 10-20-2003, 10:19 PM   #2 (permalink)
Maverick
Team Arctic
I also switched out my stockies for a set of vforce3's on my 01 ZR600EFI, the sled idles at about 750RPm (half what it should be). Vforce says I shouldnt have to rejet, any suggestions? Plugs look fine, it IS old gas, so its probably separated and everything else is stock. I was told that the EFI just has to reset the idle. Is this correct and if so how long does the computer take to get that done?
Maverick is offline   Reply With Quote
