well im in the process of seeing all parts ill need to change primary clutch...
Any ideas what all should be changed when changing clutch?
Is the secondary clutch pretty much done for since it has no adjustment left(sheive width)?
Is there any spots of excessive wear i should look at...?
what lube/grease do you use to lube the jackshaft and driveshaft bearings?
