Old 11-05-2009, 02:01 AM   #1 (permalink)
theonethatiam
Kentopatamus Rex
Question 99 Ski-Doo SummitX 670
Got a 99 Ski-Doo SummitX 670 really cheap because the guy who owned it before pulled the shaft with the rotary valve to replace the brass gear on it. The new gear is a high performance model and it is longer than oem by about 1/2 in. My question is do I need a different spring. I don't know the technical part name but it goes over the shaft and presses everything together. Do I need a shorter spring and what effect will the longer gear have on the engine?
Thanks in advance.
1995 Polaris Indy 600 XCR
Life is what you make it. If you don't make it, that's life.
theonethatiam is offline   Reply With Quote
Old 11-08-2009, 02:23 PM   #2 (permalink)
theonethatiam
Kentopatamus Rex
Nothing? C'mon guys. I just need to know if I need a different spring.
Old 11-08-2009, 08:42 PM   #3 (permalink)
OnlineMicrofiche Index will show you pics of the part you need.Let us know which one it is.
Old 11-09-2009, 05:49 PM   #4 (permalink)
theonethatiam
Kentopatamus Rex
This site did not have my sled listed. Found a picture at Babbitts. The gear being replaced is #20 and the spring is #21. The gear we have is supposed to be slightly larger than stock (about 1/2" longer). I need to know if I need a different spring (21) or if I was lied to about the gear.
Could not post a pic or hyperlink that worked so...
Babbittsonline.com -> OEM Parts -> OEM Part Diagrams Look Up by Model Fit -> Ski-Doo -> Ski-doo -> 1999 -> Summit -> Summit 500/X 670, 1999.
This should bring up diagrams for the sled. Choose Crank Case, Rotary Valve, Water Pump out of the drop-down menu and you will see what I need.
Hope all of that made sence.
