Old 07-04-2009, 11:57 AM   #1 (permalink)
supercatzr500
zr 500 timing or carbs?
What would make my zr 500 kind of bog out once in a while its like it dies for a few seconds then goes like snot again. one plug is good the other is rich looking. changed fuel pump and cleaned carbs. any thoughts?
supercatzr500 is offline   Reply With Quote
Old 07-05-2009, 05:14 AM   #2 (permalink)
Electrical problem.
Old 07-06-2009, 07:56 AM   #3 (permalink)
kccats
Start with cutting a 1/4" off the plug wires and then screw them back on good and tight! Fresh plugs. And like I asked in your other post, is it APV?
Old 07-06-2009, 10:01 PM   #4 (permalink)
supercatzr500
yes, it does have the apv's but they are definetly hooked up correctly. And would that cause it to die out sometimes, you would think it would just run horrible all the time if it wasnt opening up at startup or full throttle. The plug wires, caps and plugs are also brand new, they are actually the the red racing ngk wires and caps, so i doubt that could be the problem. im starting to wonder if the key in the flywheel slipped and that put the timing off or something, Im stumped.
Old 07-07-2009, 12:06 AM   #5 (permalink)
Check the throttle pivot pin bushing, this wears and can be replaced rather than disabling the throttle safety switch in the throttle block assembly.
